Old 03-17-2014, 10:31 PM   #1
Strykerta
Need some pro advice on rear suspension. Extremely narrowed rear.
Well i will post a shot of what im dealing with. I have a custom 9 and some 15x14 wheels. The perch distance on stock rear trailing arms is around 40 inches. My setup will require them to be at 35 total space. Which means i need to bring each in 2.5 or so which will take the rear back a small amount but not what im concerned with. I guess what im looking for is opinions on whether i should try to use stock style trailing arms from cpp or porter or do some type of custom triangulated 4 link. I wont be able to have trailing arm coils so i will have to go coilover either way. Also im not worried about having to clearence the perches or the crossmember to get the correct geometry. Has anyone done anything similar to this on here? Which will be the best option for a mild pro touring build. Tires are gonna be mickey thompson sportmans that are 31 tall and the drivetrain is a 6 liter ls and 4l80e. Thanks for any help guys
Strykerta@hotmail.com
Strykerta is offline   Reply With Quote
Old 03-17-2014, 10:39 PM   #2
Strykerta
Re: Need some pro advice on rear suspension. Extremely narrowed rear.
Old 03-18-2014, 01:20 AM   #3
andrewmp6
You kinda only have two options a parallel 4 link or maybe a custom 3 link with a nice long torque arm.The parallel 4 link would be the easier of the two to do.
andrewmp6 is offline   Reply With Quote
Old 03-18-2014, 08:03 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I would give Porterbuilt a call and see what John's advice is.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-18-2014, 08:47 AM   #5
Hertzdaddy
You might try posting in the racing forum. They have a lot of experience with setups like this.
Hertzdaddy is offline   Reply With Quote
Old 03-18-2014, 10:23 AM   #6
PBFAB.COM
PBFAB.COM's Avatar
I would recommend going with an inboard parallel four link. We are working on one right now for a customer who is running a similar set up. Shoot us an email if you would like some more info/pics. Should have some to share in a day or two.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 03-18-2014, 10:45 AM   #7
Strykerta
Thanks guys. I sent ya an email Nate thanks for any info.
Old 03-18-2014, 06:58 PM   #8
robnolimit
robnolimit's Avatar
It really doesn't look that narrow. What is the distance between the rims? and, the overall width of the rear axle.
Trailing arms can be used, but the front mount will need to be addressed. Changing the front of the trailing arm to a pivoting adjuster is an option. Keeping the suspension components as 'wide' apart as reasonable will help in ride and handling. Even to pull the rails in farther and keep the bars/arms/links and coil-overs outboard. Is this mostly a cruizer, or will it be going to the drags? You can keep the trailing arms for a cruizer, but go to a 4-link for straight line traction.
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 03-18-2014, 07:49 PM   #9
Strykerta
Rob thats exactly what i was considering. Its 39.75" between rim edges and with tires the section width is around 18 so i lose 3 inchs off the total. i flexed the trailing arms into position and it didnt seem like i would need to do to much on the crossmember to get them to that corrected angle. I was just concerned with handling with the arms being narrowed up. The truck will be a cruiser but all the motors i have are 500 hp and up so i want it to be able to handle a thrashing every now and then.
Old 03-19-2014, 06:53 AM   #10
PGSigns
PGSigns's Avatar
Find a set of the Nascar trailing arms. They have a pivot ball in the front. Should easily get you what you need. My set was $80 from a local racer. When you weld up the pads and panhard bar mounts weld slow and not in one spot long. Will keep the distortion on the tubes to a minimum. When we were building drag cars the housing ends were the last to go on when all other welding was done. I have fixed housings that moved 3/16" from the welding.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-19-2014, 07:40 AM   #11
Strykerta
Any chance you have any pics of what your talking about. I havent heard of them. I assume your just talking about putting a heim joint on the existing arm?
Old 03-19-2014, 12:20 PM   #12
mongoose
mongoose's Avatar
Id run a torque arm personally...
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 03-19-2014, 02:36 PM   #13
PGSigns
PGSigns's Avatar
No where the bushing would go in the front of the trailing arm there is a ball swivel in that location that is 1 1/2" in diameter. Much heavier than any rod end. Just do a search on ebay and most of the time there are several sets for sale.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-24-2014, 11:40 AM   #14
Strykerta
Jimmy Im not finding anything in the 1-1/2 size. All ive been finding are the johnny joints and ballistic joints in 2" which i guess i could use just would have to cust and weld them in. Over the weekened i pulled the wood bed out rolled the rear end in and it looks like i need to narrow the rear frame up a bit. Looks like im going to get the plasma cutter and some 3/16 plate and make my own backhalf. Not sute if inbound parallel or a triangulated setup will fit better need to cut the bumpstops off so i can slide it up and measure. This project just got a whole lot more involved.
