Does this look right to you?
Full disclosure, bit of a newb here with a 67' Chevy CST 327
The bearings were shot on my water pump so I replaced it with the help of a friend. I hooked everything up exactly the way it was but I'm now comparing it to other pictures and it doesn't look the same. It seems to run fine with no coolant leaks but I want to make sure it's hooked up correctly. The right angle adapter coming out the top of the water pump is what I'm questioning. Can someone please explain a little theory of operation here and why I feel like I have too many hoses coming out this thing. Which hose goes where? I'm NEW! http://imgur.com/FkbTlaN http://imgur.com/djbiGe9 http://imgur.com/zgxH88O Thanks guys Deano |
Rusty Nuts
Re: Does this look right to you?
I have never seen that extra hose on top of the water pump on my old trucks. Although there is a plug on top of them, I will be interested to here comments on what is for.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
The new water pump came with a plug already in it, just as I've seen lots yours plugged up in these forums.
I can always put a plug back in it, but I'm confused. The guys at the parts store never seen the right angle, nor could I find a replacement, which makes me question if it's supposed to be on there in the first place. How is everything supposed to hook up? How does the pump flow and in what direction? The directions in the box were kind of vague. |
That sure look to be a boat motor or industrial motor (originally).
What makes you say that?
Another weird thing I noticed was no fan clutch. |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
I've seen that bypass on the larger trucks before.. why it's used I have no clue
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
![]() Join Date: Oct 2013
more common on big blocks. helps to allow coolant to circulate through the engine before the thermostat opens. the engine will heat quicker and help prevent hot spots (air bubbles).
which reminds me, I'm pretty sure I need a new thermostat.
thanks guys |
you dont need it, i would remove it and put the plug back in the wp. for sure would look neater!
member #16
![]() Join Date: Dec 1999
That bypass hose came on 327 engines. I don't know if it could be a C-20 item, I had one like that.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 03-18-2014 at 01:51 PM. |
Maybe part of the HD cooling?
I have a friend with a 67 camaro that has this on his water pump it was a 350. I also found some pic on the web as well one was a 396 and the other was a 302
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 03-18-2014 at 08:43 PM. |
#13 |
350's to my knowledge never had a intake manifold with an oil filler... 283's and 302's had them, maybe others?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
