Old 03-18-2014, 12:26 PM   #1
Chevhell
Chevhell's Avatar
Rear end help in my 62
Im looking to put a 12 bolt in my 62 but not sure if later year rear ends will bolt right in ? I assume someone out there has converted over. Any help would be great thanks.
Chevhell is offline   Reply With Quote
Old 03-18-2014, 12:33 PM   #2
PGSigns
PGSigns's Avatar
Re: Rear end help in my 62
If it is a trailing arm truck it will go right in. You will need the track bar from the donor or just go to an adjustable one.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-18-2014, 01:02 PM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
60-62 have a little bit of a difference on the angle of the trailing arms I do believe. I think that Capt Fab would be the best to assist here.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-18-2014, 10:30 PM   #4
LVPhotos
LVPhotos's Avatar
I had to weld perches outside the ones from '71. I used the longer stock bar and mount. Now it is all PorterBuilt.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-18-2014, 11:06 PM   #5
HumphreyMurdoch
HumphreyMurdoch's Avatar
The perches on 60-62 are wider than the 63 & up. You can get an install kit from speedway, comes with perches, panhard mount and bar, to put whatever rear you would like in your truck. If you happen to go with a 73-87 they are 1.5" wider, than the original in your truck.
HumphreyMurdoch is offline   Reply With Quote
Old 03-19-2014, 12:32 AM   #6
Captainfab
60-66 Nut
The trailing arms are farther apart on the '60-'62's than on the '63-'72's. The '60-'64's have the long panhard bar and the '65-'72's have the short panhard bar.
