Old 03-18-2014, 08:01 PM   #1
stepside68longbed
stero
what color are the stereo wires? ill run my own speakers, I need the power and memory wire.
how do you fit/ cut the dash for after market cd player?
stepside68longbed is offline   Reply With Quote
Old 03-18-2014, 08:23 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: stero
You can probably trade your dash for a cut dash. Plenty of people looking for an uncut dash.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-18-2014, 08:30 PM   #3
BrianG
BrianG's Avatar
Re: stero
Don't cut it up!!!!! you can get a post style radio that has an input wire to hook up an mp3 player.
BrianG is offline   Reply With Quote
Old 03-18-2014, 08:43 PM   #4
stepside68longbed
Re: stero
Ive debated weather or not to cut it I just thought it would look slicker with an aftermarket... eventually im going to switch to a digital cluster so I thought I might as well go aftermarket with the stero.
Old 03-18-2014, 09:07 PM   #5
taylorbg
Re: stero
What color is your dash? I might be interested in a trade if you want a cut dash.
taylorbg is offline   Reply With Quote
Old 03-18-2014, 09:46 PM   #6
stepside68longbed
Re: stero
like a turquoise blue
Old 03-19-2014, 09:01 AM   #7
Hugh Mongus
Re: stero
The vintage stereo two post radio has a digital display. It also has Bluetooth and multiple connections for amps and other devices. There is really no need to cut your dash unless you just want to.
-Jason
USN Retired
Hugh Mongus is offline   Reply With Quote
Old 03-19-2014, 09:20 AM   #8
Andy4639
Old member
Andy4639's Avatar
Wink Re: stero
Cut it and be done. Taking a dash out of a truck isn't the simplest job. It will require a lot of work. Cut it and be done. Memory wire is yellow power Red and black is ground. It's your truck and if done right will look as good as any other mod done as long as it's done right.
I get a kick out of every post about not cutting the dash. Like it's some unholy thing, yet they lower them cut the frames off, put 24" wheels on them put new motors and transmissions in them change the seats add consoles to them but heaven forbid you cut the dash!
Just cut it and be happy with your truck!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-19-2014, 09:44 AM   #9
BrianG
BrianG's Avatar
Re: stero
Kind of depends on if you may want to sell it down the road later. A cut dash will turn some people away, such as notched frames and bags will turn others away also. Then again, some other's might say... cool, now I don't have to do that, you've already done it. It isn't a big deal to cut the dash really, just take your time and it will look okay. Some prefer the clean, 'vintage' look, while other's like the custom look. To each their own. I agree, It is NOT an easy task to remove and replace the dash though.
Old 03-19-2014, 07:15 PM   #10
stepside68longbed
Re: stero
hahaha yeah im nit a big fan of those trucks that cant even cross a pebble lol. im going to level my truck out with some old fashion race wheels.
Old 03-19-2014, 09:52 PM   #11
swamp rat
swamp rat's Avatar
Re: stero
Ya know your stock radio can now be converted to play a flash drive, FM, you name it..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-19-2014, 09:54 PM   #12
stepside68longbed
Re: stero
ill cut this one for now they have a dash replacement for 72 bucks on lmc
Old 03-19-2014, 10:00 PM   #13
stepside68longbed
Re: stero
I have no radio right now and don't currently have the money to drop 300 on a stero im ab to make an 8 hour trip (moveing to GA) so some tunes would be greatly appreciated
