tie rod ? for akward combo
I have 79 c10 spindles which are 11/16-18 thread and a rack and pinion from a 87 thunderbird which has 9/16-18 thread. I was hoping I could find a c10 tie rod that wpuld fot the 79 spindle that also had a 9/16-18 thread so I could use a stock adjuster. Wpuld a 71-72or maybe older one fit this application.
![]() Join Date: Jan 2011
Re: tie rod ? for akward combo
I would call the guys at Art Morison and ask them about the adapters you need. The do a lot of different rack setups and may have something to help you get the correct parts.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Ill have to google them after work and see wuat they have. I was reading through the moog catalog at specs on tie rod ends and it looks like the 88-95 c1500 inners might he a close fit. Have to get to the yard and pull one and see.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
| Bookmarks |
