Red
Which plugs ?
I need to change plugs soon and was wondering what brand and # do ya'll like? ( # on the plug not how many do ya'll like to replace) I'ts a mild manered 350 with a Th350.
Thanks Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
Formerly yellow72custom
I have had good luck with just regular AC Delco plugs....R45T plugs for that matter. Gap them at .045" with HEI, or around .035" if you are running a points igniton.
Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
20' Daredevil (Ret)
![]() Join Date: May 2003
With several SBCs over the years, I've had some bad luck with Champions, and never a problem with AC Delco. Just put a fresh set of R44TS @ .045" (HEI) in my mild 350.
Red
Thanks for the info. What is the diff between R 44/R45?
M
20' Daredevil (Ret)
Different heat range. Check this out http://www.acdelco.com/html/pi_plugs_ident.htm .
I just put in what my (trusted) parts guy said to use! Edit: I just went to that Delco site and used it to find their recommended plug - it's R44T. My TS is same plug but with extended tip. Pretty handy site; it lets you search for a wide range of AC parts for specific vehicles.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 07-26-2003 at 10:41 AM. |
I have used both R44Ts and R45Ts....couldn't tell much of a difference. What is the difference in the heat ranges anyway? Is it just the gap of the plug?
20' Daredevil (Ret)
No, the gap should be the same for either plug - .035 points, .045 HEI.
I don't know the specifics about heat range, and I couldn't find that info on the AC Delco website - only that the number indicates a difference, and doesn't relate to a value, or something to that effect.
