Old 03-19-2014, 12:37 AM   #1
Hatzman
Hatzman's Avatar
What fan are you using on your LS conversion?
I was planning on using the stock clutch fan that came with the LQ9 motor. I have been hearing though, that you cannot use the fan and shroud because it doesn't fit, and I would need to go electric.
Is anyone using a clutch fan instead of electric fans?
Thanks!
Steve
___________________________________
http://67-72chevytrucks.com/vboard/s...d.php?t=618848
Hatzman is offline   Reply With Quote
Old 03-19-2014, 07:48 AM   #2
hugger6933
Re: What fan are you using on your LS conversion?
While I have not yet done one one a 67-72, I have in a 68 LeMans convert. I did this many years ago before it was popular like 2005 or 2006. I used the fan clutch and fan off off the 6.0 truck motor I used. So surely you can use one on a truck using the mounts of today. You will love it.
hugger6933 is offline   Reply With Quote
Old 03-19-2014, 08:48 AM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: What fan are you using on your LS conversion?
I had plan to use the fan clutch out of the 6.0 in mine but using the stock 71 Chevy truck radiator it wasn't going to work along with the intake Mass air flow senor. The two of them were right in the fan area. The shroud was cut up to try and make it work but in the end I went electric.
If you buy the new radiator that mounts the top hose on passenger side then it should be Ok I would think.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-19-2014, 09:11 AM   #4
Ridgeclimber
I installed a LQ9 6 liter into my 1968 c10 last year. I used the early classic enterprise engine mounts and trani mount. The original fan with clutch hub works good. I just have the small fan guard on the top of the rad and everything clears. I also still have the original two core rad with Evans Waterless coolant and it seems to keep the 6 liter cool in the summer heat so far.
Ridgeclimber is offline   Reply With Quote
Old 03-19-2014, 01:34 PM   #5
wgeyer88
Andy,
where did you get those electric fans? The fit looks good and they look pretty clean!
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 03-19-2014, 05:27 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
I'm using Dodge Intrepid fans. Cheap as hell at the junkyard, and they really move some air.
I welded threaded aluminum bosses to my radiator, and bolted the fan to those.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-19-2014, 06:23 PM   #7
ls1nova71
ls1nova71's Avatar
Thanks!
My stock 5.3 fan fits the original small block fan shroud on my 71 like it was made for it. There's pics in my build threads in my sig.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-19-2014, 07:37 PM   #8
Roostboy102
Roostboy102's Avatar
Same here! Wasn't a challenge at all with my 4.8 clutch fan
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 03-20-2014, 12:22 AM   #9
Hatzman
Hatzman's Avatar
Thanks for all the input! For those that are using the clutch fan and original shroud, how was the engine mounted? And was it mounted in the stock position? Did you have to cut out and add a high transmission hump?
Thanks!
Steve
Old 03-20-2014, 03:21 AM   #10
mcmlxix
Collector of Projects
mcmlxix's Avatar
My LQ9 didint come with a fan.. so I picked up a two speed 2004 Jeep Grand Cherokee fan... fits in the factory small block shroud. I just used a couple bolts through the side.
Rich
1972 K5 Blazer CST Click HERE
Old 03-20-2014, 03:49 AM   #11
jamesjones
Freakin Awesome!
jamesjones's Avatar
I'm planning on using Ford Windstar fans.
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee
jamesjones is offline   Reply With Quote
Old 03-21-2014, 12:04 AM   #12
68c10airstream
68c10airstream's Avatar
Hi Steve, I installed a 2001 5.3 with fan clutch, used the 2001 truck mounts, and made my own motor mount perches so i didn't have header and gm low mount ac compressor clearance issues. In the midst of mocking up my ac lines now. I recently pulled the motor to remove the truck oil pan and install the f-body oil pan, nice clearance now. My suggestion to you is this (if i did it all over again), use either trailblazer mounts and brackets of 98-02 f-body mounts and brackets (ls-1) and then fab this to bolt to your stock cross member and avoid header headers rubbing on stock perches on the top of the frame rail, avoid ac compressor issues (if using gm type) when installing dirty dingo style adapter plates. I realize my approach isn't the norm, as a lot of people like the convenience of the dirty dingo plates, but i love to do fab work and i have no clearance issues and no regrets! Good luck, Brian Fuller.
68c10airstream is offline   Reply With Quote
Old 03-21-2014, 11:14 AM   #13
littlevictories
I'm using a '95 crown vic electric fan. But I probably could have used the stock clutch fan.
I used some cheap ebay engine mount adapters in the middle location, stock '66 v8 style mounts and the stock perches in the rear location.
littlevictories is offline   Reply With Quote
Old 03-21-2014, 12:06 PM   #14
Matt Cramer
Using the stock 2007 clutch fan and currently no shroud (there wasn't one on the truck when I got it with a 350). From what I've heard, it should clear the stock shroud without too much hassle.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 03-21-2014, 08:03 PM   #15
Hatzman
Hatzman's Avatar
Thanks for the input guys!
I just put in an order with CPP and purchased the CCP Perch (new part they just released), CCP deluxe Trac Bar, Dough Thorley headers and the CCP Slider mounts. Going to post some pics in a new thread of CCP's new parts and their Chevy frame off resto they had at SEMA.
Working a double tonight, so will post when I get home in the morning.
Enjoy your weekend boys!
Steve
Old 03-22-2014, 02:28 AM   #16
crazy longhorn
Fabricate till you "puke"
Dual 14" fans, on a hand built shroud....it kept my 383 cool, on the hottest days.....bet it will work, with my 5.3 Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
