Bench Seat For 65 Question
I've just bought a restored '65 but the seat doesn't work for me. I think I'd like to go back to a bench seat. My question, can I use a bench seat from a 72 C10?
My current seat is 61" wide. Thanks in advance. Once I figure out how to post a picture I'll post a pic of the seat, maybe someone a little smaller, I'm 6'2" 220lbs, would like it just fine. |
Never Ending Projects
Re: Bench Seat For 65 Question
Yep. I have put '68 and '72 bench seats in my old '65. Bolts right in.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Awesome, thanks.
#4 | |
I used a 89 ish seat....i like it better as you sit in the truck more and more leg room...two holes matched up
![]() Join Date: Mar 2005
Yep, same here. I'm a big fan of those seats, especially if you can find one with the flip down armrest.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Thanks brokenspoke, I may have found a better option at a junkyard today. It's a bench seat from a 80 something Cheyenne. It's better in that it tilts, but seems to sit higher and has plastic around the frame. Should I remove the plastic? Or paint it black. It also has a shoulder strap and retractable seatbelt, should I use them as well? I want to go with a black seat, can you get new belts to replace the old retractable GM belts?
Chevyrestoguy, I saw you had to cut the seat down on your '64. Did you cut it down to 14.25 inches? It looks like it's coming out of a truck about the same year as this Cheyenne.
#9 | |
And yes, the seat in the picture is the same basic one I used. Mine is a little earlier version that has no headrests, and it was out of a standard cab Silverado, so it has the flip down armrest.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 Last edited by chevyrestoguy; 03-20-2014 at 12:20 PM. |
Chevyrestoguy, what do you think about the seat covers you can buy at LMC or TruckandCarshop vs paying for a complete new cover? Are they as durable? Similar Quality? Do you generally have to replace the foam to get a quality seat for the long haul of using your seat as a daily driver? I found a seat which has better foam but it costs $130 more...about the costs of probably replacing the foam with new foam.
| Bookmarks |
