Old 07-25-2003, 07:58 PM   #1
brad20653
big or small block
What do u think in my 72 chevy long bed big block or small ?? I want alot of take off power with just stock ??
brad20653 is offline   Reply With Quote
Old 07-25-2003, 08:03 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
The big block is going to make more power....especially if it is a 454....but parts are more expensive and you will be lucky to get more than 12mpg out of almost any big block
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-25-2003, 09:13 PM   #3
brad20653
its just my 350 has only 300 miles on it and no power at all whats a single change i could do to give it low end power cam ??
Old 07-25-2003, 10:38 PM   #4
lukecp
lukecp's Avatar
So you have a rebuilt 300 mile 350?
If it is a stock motor...it should have a small cam and be good for low end power. Keep in mind it won't make full power until it is broke in...full break in will happen after 4000 or so miles. Assuming your carb and ignition is in good shape, and you want more low-end power, you will proably want to do some simple upgrades...if you have single exhaust, switch to a set of free-flowing dual pipes, if you already have duals a pair of headers might make a difference in low end power, maybe a aftermarket dual plane intake manifold, and if you have a 2bbl carb, a switch to a 4bbl would make quite a difference.
Old 07-25-2003, 11:07 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: big or small block
If you want a lot of take off power, you're looking about 10 feet too far forward.
Change the gears to a deeper ratio. That'll do it.
Old 07-26-2003, 01:37 AM   #6
miket
miket's Avatar
okay to confuse things abit...how about a "BIG" small block...383/396/406/427/454?
Or a "BIG" big block? 496/502/540/572/632?
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
