Best place to get seat belts for bench seat?
Where is the best budget place (LMC, Brothers, Bob's, etc...) to get a set of black retractable seat belts for a '68 with a bench seat?
"Now all I need is a shop to go with my shop vac!" ![]() |
Re: Best place to get seat belts for bench seat?
-Jason USN Retired |
#3 | |
![]() Join Date: Feb 2011
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
i was going to get mine from classicparts...ill check that place out though
http://www.classicparts.com/1967-72-.../#.Uyr-YIV1qSo |
Thanks guys. I just wanted to know if there were any issues with the mounting position of the retractable from Seat Belts Plus as say compared to the way the original retractable was mounted? I just know there is not a lot of room there between the seat, the gas tank and the door frame. The first pic is an original the second one is an aftermarket mounting style. The original seems to be off-set mounting hole (due to the lack of space) and the aftermarket mounting hole seems to be more centered.
MIGHT TRY THIS PLACE
http://www.andoverrestraints.com/ I DO BELIEVE THEY ARE THE ONES THAT MADE ALL GM SEAT BELTS AND ARE STILL IN BUSINESS. I BOUGHT SOME FOR A 68 CAMARO FROM EM QUITE A WHILE AGO AND OF COURSE THEY WERE PERFECT. GOOD LUCK |
sorry about the caps too lazy to turn it off lol
