Old 03-20-2014, 02:20 AM   #1
98Murray
98Murray's Avatar
Cab Lights
Hi, I have a question about cab roof lights for these trucks. How exactly do they mount to the roof? Also I would like some up close photos and some wiring help if anyone has some, I am wanting to put a set of original style cab lights on my 1985 GMC 2500. Thanks
98Murray is offline   Reply With Quote
Old 03-20-2014, 03:40 AM   #2
98Murray
98Murray's Avatar
Re: Cab Lights
After about an hours worth searching I found the answer I was looking for thanks to this great post by BLE 'BURBAN http://67-72chevytrucks.com/vboard/s...3&postcount=12
Old 03-20-2014, 07:33 AM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Cab Lights
a member sent me these,might help
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-20-2014, 07:54 AM   #4
98Murray
98Murray's Avatar
Re: Cab Lights
Thats awesome!! Thank you so much!
Old 03-20-2014, 08:47 AM   #5
mrolds88
Re: Cab Lights
One thing I did on my CC was to replace those pesky u clips with rivnuts. Also used some stainless allen bolts to hold them down.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 03-20-2014, 09:16 AM   #6
98Murray
98Murray's Avatar
Re: Cab Lights
Cool, I think I will do that to mine too. I hate those U clips lol
Old 03-20-2014, 09:37 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Cab Lights
member
Tx Firefighter has a cool vid clip how to get the wire up to the roof
used compressed air to blow a string up first
John
Old 03-20-2014, 09:50 AM   #8
98Murray
98Murray's Avatar
Re: Cab Lights
member
I saw the thread for that this morning but the video wouldnt play because it said the account had been de-activated?
Old 03-20-2014, 12:46 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Cab Lights
Old 03-20-2014, 12:49 PM   #10
Tx Firefighter
Re: Cab Lights
I like to use Rivnuts myself.
And stainless steel screws.
Old 03-20-2014, 02:36 PM   #11
mrolds88
Re: Cab Lights
Hey Kevin, do you have any info on that installer?? Looks neat!!
93 K2500 xcab 6.5TD
Old 03-20-2014, 02:44 PM   #12
Tx Firefighter
Re: Cab Lights
I got the rivnuts and the tool both from Aircraft Spruce and Specialty. The tool was inexpensive. Not sufficient for a full time airplane shop but good enough for old truck guys. Rivnuts are a great "tool" to have in your toolbox. They're very handy if you want to make a ground connection to sheetmetal or install things like these cab lights.
Old 03-20-2014, 04:31 PM   #13
98Murray
98Murray's Avatar
Re: Cab Lights
Thanks TX Firefighter!!
Old 03-20-2014, 07:11 PM   #14
liftlawssuck
liftlawssuck's Avatar
Re: Cab Lights
As a long time aircraft mechanic. I can say that rivnuts are good and bad for some applications. I would get the ones that have a little dimple under the flange. It helps them from spinning when tightening or being loosened. You must drill a hole then take a small file and file a slot to except the dimple. You can also slide an internal lock washer under the head or even on the back side and squeeze against it sandwiching it between the rivnut and sheet metal. This will help it from spinning when taking it off in the future. You also have to be careful squeezing it. Being aluminum the threads can be pulled out easily. At least the ones from Spruce can. You can get steel ones but are harder to work with. Just some useless info for anyone who cares.
liftlawssuck is offline   Reply With Quote
Old 03-21-2014, 02:19 AM   #15
mrolds88
Re: Cab Lights
Thanks, Kevin. $20 ain't bad at all!!
93 K2500 xcab 6.5TD
Old 03-21-2014, 04:06 AM   #16
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: Cab Lights
And if you noticed I rewired my 2 outer lights to flash with the side marker lights which flash alternately with the front turn signals.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 03-21-2014, 09:33 AM   #17
johnnyclack
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
Re: Cab Lights
Great info: I used (for years) them in the transit industry, I can use this tip....
johnnyclack is offline   Reply With Quote
Old 03-21-2014, 05:20 PM   #18
98Murray
98Murray's Avatar
Re: Cab Lights
Thanks for the help everyone! I took the cab lights off our rotted out 1979 C60 down in the pasture and mocked them up on the truck. They look good. I belive they are the same as what they put on the pickup trucks. These are all cracked and busted up so they will be replaced with new ones. http://www.truckspring.com/heavy-dut.../VSM1313A.aspx
Only thing left for the looks of this truck is a simple black push bumper like the one pictured below and a 5th wheel tailgate.
