Old 03-20-2014, 08:08 AM   #1
voxnor
voxnor's Avatar
Old Air Products - Series 350 Under Dash A/C
Has anyone installed one of these in our trucks? If so, how well does it fit centered under the dash?
I do not have factory A/C, but do have an existing under-dash unit that I would like to upgrade. I love the look of the Old Air 350 series, but I can't figure out how to gauge fitment - it could look very good or very bad based on angle it mounts at and how much it protrudes from the dash...
For reference: http://www.oldairproducts.com/catalo...e-p-16292.html
69 C10 LWB - "The Green Truck"
Build Thread
voxnor is offline   Reply With Quote
Old 03-20-2014, 08:46 AM   #2
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Re: Old Air Products - Series 350 Under Dash A/C
I've got old air products model 300 I don't know if that 350 series is about the same size or not ? I like the underdash ones cause they look cool they work good too !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 03-20-2014, 12:13 PM   #3
TheSeeker
I have been trying to decide between the 300 and the long underdash slimline unit for a few weeks now.. If it is possible do you have any more photos showing your AC from the sides/passenger seat etc? I want to leave my factory heat box hooked up and dont know how to mount an ac in there.. Thanks!
TheSeeker is offline   Reply With Quote
Old 03-20-2014, 01:36 PM   #4
19673ontree
CAN'T FIX NOTHIN
If you use this one like I have you don't have to do anything to your stock heater I will take you some pics when I get home today ,,,,
underdash AC
Old 03-20-2014, 02:04 PM   #5
TheSeeker
Thats awesome thank you!
Old 03-20-2014, 05:16 PM   #6
19673ontree
CAN'T FIX NOTHIN
Here is some better pics old air products model 300 1967 c10
underdash AC
Old 03-20-2014, 05:18 PM   #7
19673ontree
CAN'T FIX NOTHIN
Center
underdash AC
Old 03-20-2014, 05:25 PM   #8
TheSeeker
This looks better than I was thinking.. I wonder if its possible to mount it under the glove box where there is a bit more depth than under the Heat controls.. I have a floor shift so ill have to take some good measurements.
Old 03-20-2014, 07:50 PM   #9
19673ontree
CAN'T FIX NOTHIN
Well I guess you could mount it under the glove box but mounted in the center it distributes the cool evenly ,,,
underdash AC
Old 03-20-2014, 08:12 PM   #10
voxnor
voxnor's Avatar
@1967 .. Is the angle that is mounted at necessity by the size? Or did you purposefully mount it pointing that sharply up?
Build Thread
Old 03-20-2014, 08:18 PM   #11
19673ontree
CAN'T FIX NOTHIN
Thats the way it fit ,,,you lay it down towards the seat and it would make the truck a two passenger ,, cant have that ,,,
underdash AC
