One Ton Pic Request (Rear Frame) PICS ADDED!!!
Does anybody have a pic of a one ton truck (133" wheelbase) with no bed on it? I specifically need a pic of the frame from behind the cab to the end of the frame. I have '71 ton, and I need to verify number and location of crossmembers. I think I may be missing a few.
![]() Thanks in advance. BBB Last edited by BigBlockBurris; 03-23-2014 at 05:53 PM. |
Re: One Ton Pic Request (Rear Frame)
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#3 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Picture enough or do you need a drawing?
Send me your email if you need it (fullsize).
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Thank you both for the reply.
The pic Tim put is exactly what I was hoping for. I am missing the rear most crossmember. Thanks again! BBB |
One more then.
Tim,
Thank you again. That rear cross member is exactly the one I am missing and that I need. Got one? Thanks! Alex |
What I need!!! BAD!!!!
Guess someone thought that the receiver hitch was enough.
As far as locating one. Dude, I live in California. However Jenn and Jeremiah King may very well have one but shipping could be expensive to NC. www.kingstrucks.com They are members here on the board jeremiah king http://67-72chevytrucks.com/vboard/member.php?u=41714 Might be best to find a local cut off frame section and someone to huck fasten the crossmember into your truck.
Tim-I know shipping would kill the deal, I was just picking.
I have looked local with no luck. Thanks again for your pics, and help. It appears that whoever removed mine, did a neat job, thank goodness. I hope to find another to put back. I agree, the hitch is not enough. BBB |
![]() Join Date: Aug 2003
Wouldn't 3/4 be the same on leaf spring truck?
#12 | |
![]() Join Date: Oct 2009
![]() Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
#13 |
Good point!
Looked it up in the parts manual and the service part only fits 30s and 133"wb 20s (Longhorns). There are different numbers for 10-20 applications. Good news is the part seems to backfit to 1955.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 03-23-2014 at 08:28 PM. |
#14 |
Let me look, tomorrow, I have a 1 ton I am parting out, the frame rails had some rot so I am cutting it up.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
#15 |
![]() Join Date: Mar 2003
What you need is a frame with the inside measurement of about 4.25'' and a center to center on the back most rivet of 31''. I just measured my longhorn x-member
#16 |
Here are the couple pics of mine, Sorry but I've got a fuel tank sitting there. fit nicely inside the frame rails so it doesn't roll.
