Old 03-20-2014, 11:14 AM   #1
3QTRTONS
3QTRTONS's Avatar
Another frame swap ?
Searched, but was unable to find an answer.
Considering using a 2wd frame from a '74 C20 under a '74 K20 - AND putting the '74 4x4 running gear back under it. Any help on this appreciated..........
1969 ES5500 B E A S T / 1974 K20 / 1976 K20 Suburban / 1983 C10 'farm truck' / 1984 K10 Suburban / 1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 03-20-2014, 11:28 AM   #2
Wrecked1982
Wrecked1982's Avatar
Re: Another frame swap ?
there is a couple of swaps like that in the -All 4x4 Tech & Off Roading- section. it basicly involves swaping all suspensions brackets , hump floor depending if manual or auto, drilling the hole to install the front swing shackle and more..but its doable
Wrecked1982 is offline   Reply With Quote
Old 03-20-2014, 11:30 AM   #3
hatzie
Moderator
hatzie's Avatar
I think the 10 series used different frames from the 20 & 30 series... but I'm not positive.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-20-2014, 11:47 AM   #4
crashz
crashz's Avatar
There is a distinct difference in frames on the C30 vs K30 135.5 inch wheel base cab and chassis frames. On 10 series I'm not sure. 20 series, I think if the wheel base is the same the frame is the same, however the suspension (front and rear) and hangers are different.
2012 Chevy 2500HD, 6.0L, 6spd auto, 4x4, ECSB
1987 GMC V3500 Dump, 6.2L diesel, TH400
1983 GMC K2500 - awaiting its restoration and Cummins swap.
crashz is offline   Reply With Quote
Old 03-21-2014, 10:07 PM   #5
Ziegelsteinfaust
I just finished swapping the body from a C20 to a K20 frame.
The body is the same except for the High hump, but the brackets can be done easily enough. Just take your measure twice, and cut once. The main difference I see is the K series frame is flat on top to help hold the engine mount bracket.
At this point I would consider 52 inch springs, and or another type of front suspension if you ever wanted it. As it would just as easy to do now.
Ziegelsteinfaust is offline   Reply With Quote
