Old 03-20-2014, 12:31 PM   #1
rmv23887
72 C10 Dynmat/HushMat install Opions
Got the rockers/floorboards replaced, wanta Dynamat, what primer/paint you put down before dynamating and how much dynamat did you use? Firewall, doors, floor to where tank was?
RandyV
rmv23887 is offline   Reply With Quote
Old 03-20-2014, 09:19 PM   #2
72 C20 Fleetside 4WD
Exclamation Re: 72 C10 Dynmat/HushMat install Opions
I have used Fat Mat in 4 different personal vehicles with excellent results each time.
72 C20 Fleetside 4WD is offline   Reply With Quote
Old 03-20-2014, 11:05 PM   #3
Andy4639
Old member
Andy4639's Avatar
Wink Re: 72 C10 Dynmat/HushMat install Opions
I just did my 71 cab. The whole floor back wall of cab inside the doors and it took almost 2 whole boxes of road kill trunk kits. I have 3 sheets left.
Trunk kit includes 10 12"x24" pads, 20 square feet overall.
I went from bottom of the fire wall padding all the way up the back wall to where the top of the gas tank normally is.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
