Old 03-20-2014, 01:19 PM   #1
Nordic
Nordic's Avatar
SBC base timing
What do you run for base timing in a non stock 350?
The new motor is .30 over 10:1 pistons 650 cfm holley and a mild cam(
valve lift Int .420 exh .443
cam lift Int .280 Exh .295
duration 278 288\
hyd lifters (not roller) )
Some people say to advance timing until I pings and then back off 2 degrees, others say to use a vacuum gauge. I just don't want to run to advanced.
starts and runs well at 14 degrees .not enough? to much? points dist with working vacuum advance.
opinions?
Nordic is offline   Reply With Quote
Old 03-20-2014, 01:25 PM   #2
OrrieG
OrrieG's Avatar
Re: SBC base timing
That sounds about right. I usually start at about 10 degrees than advance like you said until it starts to change than back off a little. Take it out and run it up under load, if it feels good and is not popping back thru the intake you are good.
OrrieG is offline   Reply With Quote
Old 03-20-2014, 03:07 PM   #3
cleansquare
Re: SBC base timing
I like to start at 10-12*. And then go from there.
cleansquare is offline   Reply With Quote
Old 03-20-2014, 03:24 PM   #4
NEWFISHER
NEWFISHER's Avatar
Re: SBC base timing
Same combo and mine is base set at 12
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-21-2014, 09:50 AM   #5
55metalmonkey
Re: SBC base timing
Mine was set at 12 degrees for the initial start up and I adjusted from there, I'm at just under 14 now. I installed a vacuum gauge in the intake manifold and used that to tune it balancing timing and fuel adjustments to get the vac as high as I could.
55metalmonkey is offline   Reply With Quote
Old 03-21-2014, 11:11 AM   #6
Highsider
Highsider's Avatar
Re: SBC base timing
Could my HEI be 180* off? (350)
I can't get the light on a crank mark.
Hooked on plug #1.
Can I just pull it up and spin the rotor and set it back in?
Does one full rotation do it?
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 03-21-2014, 11:39 AM   #7
starterman99
starterman99's Avatar
Re: SBC base timing
IF your distributor was 180 out the engine would not run.it would not start and be popping back thru carb when cranked over.
1950 5 window
starterman99 is offline   Reply With Quote
Old 03-21-2014, 12:03 PM   #8
Highsider
Highsider's Avatar
Re: SBC base timing
It starts and runs fine. I just think the flash should light up a mark or two.
I won't worry, then.
Thanks!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-21-2014, 01:13 PM   #9
Jonzon
Jonzon's Avatar
Re: SBC base timing
I f your distributor AND spark plug wires is 180° off it will be like that. Check if #1 wire is in correct position.
Edit: Hmm..... maybe not. At a second thought it should lit the mark anyway
Chevrolet Apache 1958 350" TH700R4
Cadillac Series 62 Convertible 1955
Jonzon is offline   Reply With Quote
Old 03-21-2014, 01:19 PM   #10
Highsider
Highsider's Avatar
Re: SBC base timing
I'll scrub the wheel real good!*
*swear I saw a photo on here, of a guy cleaning his as it spun.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-21-2014, 04:36 PM   #11
OrrieG
OrrieG's Avatar
Re: SBC base timing
Pretty sure he said "hold my beer while I clean this". Then "where the H*** is my finger" when he woke up in the ER....
Old 03-21-2014, 07:38 PM   #12
fabguy
Elev8r Man
fabguy's Avatar
Re: SBC base timing
Most timing light clamps will have an arrow which is the direction of the spark plug.
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 03-21-2014, 08:23 PM   #13
Rednek13x
Rednek13x's Avatar
Re: SBC base timing
make sure your clamp lead is not draping over other leads. That will cause it to pick up a different pulse.
Rednek13x is offline   Reply With Quote
Old 03-22-2014, 10:29 AM   #14
Highsider
Highsider's Avatar
Re: SBC base timing
I am refreshing my 1406 right now, so I will give the timing light
another try a bit later.
I also need to shim my new starter, too. It screams at me.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-23-2014, 02:46 AM   #15
18inchapes
18inchapes's Avatar
Re: SBC base timing
highsider, you may have a 305 balancer. The timer mark on those are at the 12 o clock position vs. the 2 o clock position for the 350 @ TDC.
Put the engine back to #1 TDC and see where you see the mark.
I like to be at 36 degrees total timing @2000RPM
Jeff
1956 GMC 102
1952 Chevy hardtop
1932 Plymouth PB 3 window coupe
1980 Harley-Davidson FXWG
18inchapes is offline   Reply With Quote
Old 03-23-2014, 09:41 AM   #16
Highsider
Highsider's Avatar
Re: SBC base timing
Jeff
No kidding?
I never looked there.
I will see how close to 36 I am.
Thanks!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-23-2014, 10:10 AM   #17
Wheelie
Re: SBC base timing
Never trust the balancer marks! Im assuming you know but no one mentioned to unplug vacuum advance when checking timing (and run advance on PORTED vacuum, not manifold vac.). Also I like to use a compound guage (vacuum guage) when setting timing to see when vacuum drops. I start base timing @ 12-14 deg. , total timing around 34, Also another really important setting w points is dwell and it should be around 28-32. Even with all this info I still try to set it up by ear if I think the balancer spun or it just doesn't run well. I always default to road tuning and whatever the engine reacts to. SOmetimes feel and hearing is the best tool.
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 03-23-2014, 10:21 AM   #18
Highsider
Highsider's Avatar
Re: SBC base timing
Please define "PORTED vacuum".
- I tape the ends on the advance hose/ports.
- I have used the vacuum gauge and tried for the highest reading which was around 13-14 if I recall.
I make sure I like the way it starts, then road test it for any pinging and retard it slightly, get back in and test.
Any advice or tips will be considered!
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-23-2014, 10:37 AM   #19
Wheelie
Re: SBC base timing
ported vacuum is above the carb throttle plate and is always on the carb. It slowly pulls vacuum as the throttle valve is opened. If you put your finger over a ported vacuum source at idle it will be barely felt if at all but as you increase throttle it will pull more vacuum. Manifold vacuum is exactly what it is. It is a vacuum source pulled off the manifold or UNDER the throttle plate. Its vacuum will be constant and you will feel it pull a lot more vacuum at idle and usually if you unplug a manifold vacuum source while running it will run like crap until you plug it back up.
My '59 Build Thread
Old 03-23-2014, 10:47 AM   #20
Highsider
Highsider's Avatar
Re: SBC base timing
I use one of the small ports, above the throttle plate.
I was dense as to the term.
Thanks.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-23-2014, 10:48 AM   #21
Wheelie
Re: SBC base timing
Ugh, I hate edelbrock carbs. I have so many problems with those damn things. You need to get a holley! The big port is manifold for like a brake booster. The one on the left is ported I believe. the one on the right is manifold. but to be sure id test them like I mentioned earlier.
My '59 Build Thread
Old 03-23-2014, 10:57 AM   #22
Highsider
Highsider's Avatar
Re: SBC base timing
I just cleaned and installed floats and a kit, on the 1406, so I will drive it a while and see if I made any improvement.
Left outlet, is where the advance plugs in. Large one runs the PCV hose.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-23-2014, 11:51 AM   #23
Highsider
Highsider's Avatar
Re: SBC base timing
Wheelie-
You got me thinking when you said large center pipe "for a brake booster" and I have it on the PCV hose.
Here is where my brake vacuum hooks up. Should I swap it with the PCV port?
'57 Panel 3105
Met this deer...
Jim's Bread Truck
Old 03-23-2014, 12:58 PM   #24
OrrieG
OrrieG's Avatar
Re: SBC base timing
You have it right, pvc goes to carb, booster and auto trans to the manifold.
Old 03-23-2014, 01:07 PM   #25
Highsider
Highsider's Avatar
Re: SBC base timing
Cool, Orrie. Thx.
'57 Panel 3105
Met this deer...
Jim's Bread Truck
