Old 07-25-2003, 10:06 PM   #1
brad20653
Rear swap help
Can someone give me step by step maybe pictures on swapping my rear gears for 3:73's its a 72 chevy longbed 1/2 ton
brad20653 is offline   Reply With Quote
Old 07-26-2003, 08:15 AM   #2
brad20653
t
Old 07-26-2003, 02:30 PM   #3
brad20653
1
Old 07-26-2003, 03:06 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Brad , what are your current gears?. Are they 3:07's. If so, you will need a 4 series carrier to accomodate 3:73's.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 07-26-2003, 03:48 PM   #5
brad20653
i dont know what they are
Old 07-26-2003, 05:55 PM   #6
68_c10_on20s
68_c10_on20s's Avatar
gears
my best advise is do what i did take it to a shop it will cost about 800 for a new posi and gear and seals and carriers but its worth it its a pain in the azz to do....
93 Fleet Budget Build http://s150.photobucket.com/albums/s...zted71/hoopty/
68_c10_on20s is offline   Reply With Quote
Old 07-26-2003, 06:07 PM   #7
lukecp
Formerly yellow72custom
lukecp's Avatar
You need to find out what gear ratio you have right now....do you have a tach? If so, what RPM is your engine turning at various speeds?
If you do have 3.07's, and want to swap to 3.73's the cheapest way to do it would be to go pick up a used rear axle that already has 3.73 gears from a salvage yard. The rear axle will proably cost less then just a new set of 3.73 gears alone. You can bolt it in yourself, or take it somewhere to get it done.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-26-2003, 08:06 PM   #8
brad20653
no tach
Old 07-26-2003, 09:12 PM   #9
jewels.
jewels.'s Avatar
i measured my rearend by lifting the rear end and turning the tire. then count the number of rotations of the driveshaft for one full turn of the rear tire.
my gears are 3.73, and here is how i found that out:
1 turn of rear tire = 1-7/8 turn of driveshaft (or 1.875 turns)
2 wheels x 1-7/8 = 3.75 (which is approx 3.73)
this estimate is enough to give you a good idea of your current ratio.
if you cannot get it this way, or you prefer a more exact approach, you can open up the rear end and read the exact ratio off of the main gear (i believe it is marked on the face of the ring gear).
it cant hurt to open up the rear and replace the old diff fluid (which probably could stand to be replaced if it hasnt been replaced in its 30-year lifetime)
good luck!
jewels.
68 C10 Red Step 350 my first child & main focus
58 3200 Apache LWB Step the upcoming project
jewels. is offline   Reply With Quote
Old 07-27-2003, 09:07 AM   #10
Low69CST
I've got some open carriers with 3.73's. If you'd be interested in one let me know, they would need to be gone through though.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
