Old 03-20-2014, 03:37 PM   #1
Pappyx3!
Pappyx3!'s Avatar
62' SB Stepside Emergency Brake
Does anyone have a parts breakdown on the lever, mounting and cable(s)? I found the lever assy under the seat last weekend, PO might have been using it for protection... Anyway not sure what I will need to get it mounted up and working. Thanks for the help!
Pappyx3! is offline   Reply With Quote
Old 03-20-2014, 03:45 PM   #2
1963c-10
1963c-10's Avatar
Re: 62' SB Stepside Emergency Brake
Does this help any
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-20-2014, 03:57 PM   #3
Pappyx3!
Pappyx3!'s Avatar
That's a great start. the cables have all been cut.. I'm starting pretty much from scratch. I wanted to get all the info I could find cause I am in the process of doing a 4 wheel brake job (This weeks project) Appreciate the info 1963C-10!
Old 03-20-2014, 04:27 PM   #4
1963c-10
1963c-10's Avatar
NO problem....I'll give you a link to the FAQ's sections that will help out a bunch. http://67-72chevytrucks.com/vboard/s...d.php?t=559678 I think 2B is where you'll find all your answers.
Old 03-20-2014, 04:32 PM   #5
Pappyx3!
Pappyx3!'s Avatar
Thanks, I tried to use the link Woogeroo sent to the WikiGM site but I didn't get the hang of it...
Old 03-20-2014, 04:37 PM   #6
forestb
forestb's Avatar
The 62 mechanism looks allot different than that. I think you can purchase the front and rear cables from LMC or Classic Truck Parts of America. I think you need 2 rear cables that run along the outside oft the trailing arms. Where the three cables connect under the tail end of the transmission there are 3 bars and a spring. I do not think any of the catalogs sell these parts. I would look for them at the junk yard. Also there is a bracket that holds the cable in place next to the lever that you will need.
forestb is offline   Reply With Quote
Old 03-20-2014, 07:46 PM   #7
murphy98
murphy98's Avatar
Here are a couple of pages from the assembly manual showing the emergency brake set up on the 60-62 trucks which forestb described above. This e-brake setup is identical to my '62 stepside. As stated above you can buy the cables but the brackets & lever bars will most likely have to be found used from a salvage yard. Another option, the lever bars are not that complex so they most likely can be fabricated from 1/8" flat stock if you can not locate any used ones. Hope this helps.
murphy98 is offline   Reply With Quote
Old 03-20-2014, 11:24 PM   #8
Pappyx3!
Pappyx3!'s Avatar
I bet the PO did away with all the lever bars and cables when he installed the stroker & the turbo 400 trans. I would be glad to hear some opinions would I be better off to convert to the foot brake? I was doing some reading in the FAQ's about it this afternoon... thanks for all the info and feedback.
Old 03-21-2014, 06:42 AM   #9
bj383ss
bj383ss's Avatar
I have the same problem. All I have left of mine is the E brake arm and the cable that went to the connection behind the trans and the passenger side cable to the drum. I have an auto so its not a huge deal but would like an ebrake. PO on mine used the ebrake crossmember to mount the 700R4.
What I would like to do is have a floor mounted like all the new cars. Seems like it would be a lot simple connection. Not sure what donor vehicle to use though. Maybe like the one in my 02 Camaro.
If you go to a foot pedal you will lose your fresh air vent. Not a big deal and have to move your high beam switch maybe.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 03-21-2014, 08:38 AM   #10
1963c-10
1963c-10's Avatar
Bret
I think I have an extra crossmember for the ebarake....let me check. If I do you can have it for shipping costs.
Old 07-03-2022, 12:43 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Saving this thread for later reference.
The main cable that connects to the handle for the 60-62 has a different part number than the others.
66 C20 Service Truck:
Old 07-03-2022, 06:37 AM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
Are those LMC part numbers or OEM?
Old 07-03-2022, 07:03 AM   #13
LostMy65
LostMy65's Avatar
Lmc
