Old 03-20-2014, 09:34 PM   #1
ol'orange
ol'orange's Avatar
3/4-1/2 ton conversion
I have a 59' long fleetside 8 lug gmc. I believe its a GMC 152. I'd like to switch to a half ton 5 or 6 lug pattern for ease of finding and number options for wheels. Obviously the rear should be simple to swap out. But my question is for the front. Can I just remove my 8 lug hubs and replace with a 5 or 6 lug hub? Would I need to also replace the spindle or even the axle as well? Or am I just going to need to find a IFS to weld in instead? Any advice is appreciated!
Thanks A.
72' K10 LWB (Ole' orange)
59' 150 LWB (latest addition, open to suggestions)
01' Ram 1500 (great white)
98' Honda civic (cirvics)
ol'orange is offline   Reply With Quote
Old 03-21-2014, 08:23 PM   #2
jetnow1
Re: 3/4-1/2 ton conversion
Easy way is to swap a 1/2 ton axle/spindles/hubs as a unit. The 3/4 ton and 1/2 ton are
different, but will swap as a unit. They do use the same springs so no problem there. Put
a want to buy ad on craigslist, I was able to get a full front end for $100. Lots of guys
taking out the original front end to put in mustang 2 front ends.
If you want to go to IFS the frames are virtually the same, the 3/4 ton is the same shape
from the cab forward though slightly thicker steel. The rear of the frame is different- the
3/4 ton is basically straight, the 1/2 ton flairs out, therefore the 3/4 is narrower in the
rear so any kit's for the 1/2 ton will not fit. The 3/4 ton is already an open rear, while
the 1/2 ton is still torque tube (except for the last models.
If you swap to a 1/2 ton front end and want to stay with drum brakes be sure to get one
51 or later- Chevy switched from Huck style to Bendix style brakes. Much cheaper to rebuild and easier to get parts, and easier to adjust. Huck rhymes with suck!
jetnow1 is offline   Reply With Quote
Old 03-23-2014, 01:06 PM   #3
ol'orange
ol'orange's Avatar
thanks jet, just the info I was in search of!
