Old 03-21-2014, 12:26 AM   #1
Matt21lutz
Matt21lutz's Avatar
Widest tire you can run in the rear?
What's the widest tire that you can run in the rear? Truck will be bagged and not a parallel 4 link (nothing on the outside of the frame near the tires)
Need some pics of clearance!
My current ride: 1983 C10 Silverado LWB - Work in Progress
Matt21lutz is offline   Reply With Quote
Old 03-21-2014, 08:32 AM   #2
SCOTI
SCOTI's Avatar
Re: Widest tire you can run in the rear?
Drag tires or touring?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-21-2014, 01:30 PM   #3
Matt21lutz
Matt21lutz's Avatar
Touring? I think, just regular street tires, thinking about running the hr99 from coddingtons, they have a 20" x 15".
Old 03-21-2014, 01:55 PM   #4
SCOTI
SCOTI's Avatar
A 20x15 will only have limited tire selection (Mickey T Sportsman S/R Radials) so that's basically a pro-street radial & not really touring. Michelin makes a wide sticky Z-speed rated touring tire but I would guess the wheel width is usually the 12.5-13" width.
Mickey T's 18" wide version fits the 15" wheel & has 29" & 31" height options. That wide of a combo fitting between the outer bedside skin & OE rail placement will depend on how low it sits. The better option is a 20x12 or 13" wide. They'll have room to spare after modifying the tubs.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-21-2014, 09:51 PM   #5
Matt21lutz
Matt21lutz's Avatar
Talking Re: Widest tire you can run in the rear?
Didn't think of tires! haha thanks! but I was thinking that it would most likely end up being a 12, thank you for the info!
Old 03-21-2014, 10:12 PM   #6
SCOTI
SCOTI's Avatar
For the record.... A true, sticky (300 or less treadware rating), pro-touring tire that fits a 20x13" wide wheel (meaning fits correctly/not stretched) is not going to be cheap (4-500 bucks) each. Tires that fit the 12" wheels are more available w/higher treadware ratings for cheaper prices.
But.... Cheap tires are just that.... Use them just because they have something cheap that fits (or close to fitting) & you're building a 'cruiser' (not necessarily a 'touring' ride).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
