03-21-2014, 04:17 AM | #1 |
Ls swap radiators?
Hey guys I am looking for some ideas of a radiator for my ls swap.
I would really like to have a radiator, trans, engine oils all together in one unit. Anyone done that yet? What's the best thing to do? I have a/c and don't want a bunch of coolers bunched up behind the grill. Post pics and links if you have a good suggestion. 72 GMC Sierra Grande |
03-21-2014, 04:53 AM | #2 |
Old member
Re: Ls swap radiators?
Go to the LSx swap section there is a ton of info there.
03-22-2014, 02:40 AM | #3 |
Freakin Awesome!
This is what I plan on running in my Blazer...
http://www.summitracing.com/parts/gr...t/model/blazer
1972 K5 Blazer - LQ4/TH350/NP205 - Long Travel Suspension - Hooptee |
03-22-2014, 09:01 AM | #4 |
I used an Entropy and am happy with it. http://www.entropyrad.com/radiators/...ck/cat_26.html
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
03-22-2014, 09:24 AM | #5 |
Good info thanks guys!
03-24-2014, 11:07 AM | #6 |
Vintage Evil
Wondering if anyone has used this brand before? I called and they said they could build it with the LS setup with both in and out on the same side and the Trans cooler on driver side...
http://wizardcooling.com/1967-1972-c...minum-radiator I like their shroud options: http://wizardcooling.com/shroud-fan-...election-chart They also have a upgraded tube option: http://wizardcooling.com/125-tube-core-upgrade |
03-24-2014, 11:19 AM | #7 |
Those look pretty nice.
03-25-2014, 06:06 PM | #8 |
I was wondering about this myself... Will the stock radiator not work for the LS engine?
Trying to get thru my LS swap |
03-25-2014, 06:53 PM | #9 |
It's alsways something.....
I've used stock radiators from 67-72 with mechanical fan and stock shroud on 4 swaps and never had a cooling issue
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
03-25-2014, 08:36 PM | #10 |
Thanks chuck, I guess I need to get a shroud
03-25-2014, 08:44 PM | #11 |
Mine stock rad was shot and couldnt be fixex a stock replcment was 220 buxs local so i ordered thr giffin ls swap rad for 268 buxs
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-25-2014, 08:58 PM | #12 |
thanks truckdude, I think my radiator is good...not leaking or anything so I think Im ok...just depends on those shrouds, if they are expensive then I will probably get one of those griffins...did you have to put a fan on yours ?
03-25-2014, 10:44 PM | #13 |
When shoppin for an LSx swap radiator I wanted 4 things
1. Made in USA - turned out to be hard to find 2. Inlet and outlet on passenger side. Hate that giant hose across the front of motor. Looks ugly! 3. Aluminum construction 4. Reasonable price I ended up going with Griffin Dominator Series PN 8-70013-LS at Summit Racing. For a fan setup I scored a used Old Air dual fan setup from CL. Very nice piece. Having a 1967 core support this presented a little bit of a fit issue for the radiator. It's a smidge too tall. But with some fabrication everything worked out. |
03-25-2014, 11:09 PM | #14 | |
03-25-2014, 11:44 PM | #15 |
griffin is made in usa. Yes, a fan setup is needed. You have several options.
03-26-2014, 01:44 AM | #16 |
Yea i used a set of 14 inchs eclectric fans from my kocal auto part store
04-13-2014, 05:14 PM | #17 |
Can the stock 2002 truck radiator be used?
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
04-14-2014, 12:24 AM | #18 |
yeah but it's really wide…like 32" or so. i used a griffin ls swap rad for a '69 camaro
04-14-2014, 09:50 AM | #19 |
Yeah I actually just baought the griffon dominator radiator and fan on summit...should arrive today as a matter of fact.
04-17-2014, 09:54 AM | #20 |
We also make drop-in aluminum radiators made here in the USA, and we build them for stock setups all the way to LS conversions at no additional charge. We also include a trans cooler at no additional fee (when requested). Here is a link to our vendor page here, and we are a Gold Vendor for this site:
http://67-72chevytrucks.com/vboard/s...d.php?t=590670 Make sure to let us know you are a forum member, as we offer a discount! |
07-19-2018, 07:11 AM | #21 |
I'm excited to be saving up for an RnD radiator, read a ton of good reviews. They offer a 1 year warranty against manufacturing defects, and can put trans fitting in no charge, along with the steam port, relocate top right hose fitting .
Sparky, I will let you know! |
07-19-2018, 10:46 AM | #22 |
Awesome! We look forward to building your rad!
07-21-2018, 06:20 PM | #23 |
My RnD rad keeps my LQ4 running cool - +1 for Sparky.
07-24-2018, 06:17 PM | #24 |
I would stay far far away from Griffin radiators. I had 2 in my truck in less than a 3 month period that leaked like a sieve. I replaced it with a Holley frostbite and it’s held up great so far. This is the 3rd different brand aluminum radiator I’ve had in my truck since the LS Swap and it’s lasted the longest. If you’re gonna go with any of the other brands recommended in this post, I would suggest entropy. I’ve heard nothing but good things.
07-25-2018, 09:43 AM | #25 |
ol' timey brass/copper stock 4 row cools just fine with the proper fans and shroud.
