Old 03-21-2014, 08:44 AM   #1
kaysboat
Very weird and intermittent starting issue
I'm having a very aggrivating starting issue with my 1980 straight 6 three on the tree.
For the past couple of weeks the truck would randomly fail to turn over (as if it had a dead batttery). After a couple minutes of sitting, it would then fire up no problem (no labouring etc...) The issue has become progressively worse to the point now where it rarely tirns over. The lights, and radio work fine, but when turning the key to start (with clutch depressed) nothing happens.
I thought the starter solonid may have been the issue, so I changed the starter. Same issue. Bench tested the coil (integrated into the distributor cap) and I think it is fine, although I wasn't entirely sure what the readings on the multi meter were supposed to be.
I had the battery bench tested which turned out to be shot (no amps registered on the tester), so I charged up another battery which is less than two years old, but the problem still persists.
Any ideas or more troubleshooting tips?
Thanks.
kaysboat is offline   Reply With Quote
Old 03-21-2014, 08:48 AM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
Re: Very weird and intermittent starting issue
Check all the connections of the battery cables and grounds
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 03-21-2014, 09:12 AM   #3
walkerb
walkerb's Avatar
Neutral safety switch? Any difference pushing the clutch pedal harder or softer?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-21-2014, 06:23 PM   #4
kaysboat
Yes. It seems to start pretty reliabily when the clutch pedal is depressed about 3/4 of the way. Does this indicate the neutral safety switch?
