I want to rebuild front and rear shackles on my 53. Where is the best place and best price to get this stuff? Thanks guys
Re: Best place for shackles?
I honestly watch ebay for stuff like this. I have found them NOS good old original GM parts for reasonable prices, often cheaper than the reproductions. If you do buy repro LMC trucks has been very good for me.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Does anyone know which of these 2 I need for my truck?
http://www.rockauto.com/catalog/x,ca...53%2BCHEVROLET Not sure if mine is 3600,3700,3800 or 3900 |
Is your truck a half ton (3100) a 3/4 ton (3600) or a 1 ton (3800)?
http://www.cs.siena.edu/~lederman/tr...delNumbers.htm These are the same for all 48-54 that I know of. They may not have had a "heavy duty" 3/4 ton (3700) I don't remember ever seeing that. But the 3100-3600-3800 are the same. 1/2, 3/4, 1 ton respectively. Brian
So you think I would need that top part for the 3600?
My truck is a 3100 |
#6 | |
The 3600 is a 3/4 ton and I don't know if there is a difference. Usually in a case like this I start checking other reliable sources to see if the parts fit the model I need them for. Here, using the LMC Cheat sheet with 1/2 ton on this page http://www.lmctruck.com/icatalog/ca/full.aspx?Page=89 and the 3600 3/4 ton on page 90 you can compare parts numbers. I didn't say you had to buy their parts but LMC is an easy to use source for figuring out things like this. It looks like the front shackle kits are the same part number for 1/2 and 3/4 tons. There is always that chance that you can get them locally for a reasonable price with no shipping too. As an example this is what Napa shows for the pieces for a 52 3100 http://www.napaonline.com/Catalog/Re...25007/Ne-25000 You can plug in your zip code and get local list prices. They may or may not be reasonable compared to other vendors though.
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 03-21-2014 at 02:50 PM. |
Got ya. Actually my truck is a 1/2 ton and I just noticed my rear hubs are 8 lug. Also just went and picked up a front end from a guy today. It happen to be 8 lug also so I know which shackles to get now. Only problem I bet I have is finding wheels for the 8 lugs
