Old 03-21-2014, 11:20 AM   #1
rs74
rs74's Avatar
Power window wiring removal?
Getting ready to replace the power doors on my K30. How do I go about getting the wiring out. Do I need to take it out of the door or is there a connection that I can undo behind the kick panel. If I have to take it out of the door then do I have to disconnect the regulator or can it all be fished out without taking everything apart?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-21-2014, 02:46 PM   #2
rs74
rs74's Avatar
Re: Power window wiring removal?
Got it. Not sure how the factory routed the wires on these trucks. The previous owner had the wiring tucked between where the regulator and the door bolt together between the upper and lower bolts. I just unbolted the regulator and pulled the wiring out the hole in the door.
Roy
1987 R10 shortie
