03-21-2014, 12:33 PM | #1 |
55 gmc
i have a 55 gmc 150 that i installed a 79 camaro subframe on. The original radiator support was damaged so i would like to put a aftermarket Chevy support in. will this work? I assume I will have to redo some brakets or is it a bolt in operation? They look completely different in pictures. This is my 1st attempt at building a project and dont want to buy parts that I cant use! Any help??? Thanks
03-21-2014, 04:39 PM | #2 |
Re: 55 gmc
Some say there is a difference in GMC and Chevy radiator supports, but I found one from a 58 GMC and put it in my 59. I stood them up side by side and could not see and difference and so far everything is bolting up fine. Maybe the 55-57 are different????
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
03-21-2014, 05:54 PM | #3 |
Re: 55 gmc
I retained the Chevy rad support when I installed the GMC fenders and grill and did not have to do anything special. I did not use the stock radiator because I have a BBC in it so did custom Afco radiator. -Bob
03-21-2014, 08:02 PM | #4 | |||
GMCDAC
Re: 55 gmc
DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild! 1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish! 1955 GMC 100 2nd design driven almost daily! Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09 GMC driver for 30 years! |
03-21-2014, 08:59 PM | #5 |
Re: 55 gmc
DAC, no someone put a MII on the oem frame rails before I got it. And mine is a 56 - I assumed Pfdchief was referring to a 55 2nd series. -Bob
03-21-2014, 09:55 PM | #6 |
Re: 55 gmc
yes it is a 2nd series. sorry forgot to mention that part
03-21-2014, 10:17 PM | #7 |
Re: 55 gmc
I don't believe you!
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
03-22-2014, 01:23 AM | #8 |
Re: 55 gmc
I'm using a Chevy frame under my GMC. The Chevy rad support sits forward of the GMC support thus the hood latch bracket on the GMC hood is a different shape then the Chevy.
So 1 could use a chevy hood or the latch bracket from 1 and then use the Chevy latch and panel, cross piece, Grill and lower panel making the GMC grill a Chevy. Or fab a latch panel to match the GMC hood bracket and keep the GMC Grill.
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
03-22-2014, 01:35 AM | #9 | |
Re: 55 gmc
