Old 03-21-2014, 01:46 PM   #1
bryce6horse
bryce6horse's Avatar
power steering box
when i bought my truck the guy told me he had replaced the steering box and lines. the box has play in it. i had the front end checked and its all tight. is there an adjustment for this on the box or does it need to be replaced?
Rodney
1974 Chevy Big 10
1983 GMC Sierra Classic 1500
1986 Chevy K20
2013 Dodge Challenger
2014 GMC Sierra
bryce6horse is offline   Reply With Quote
Old 03-21-2014, 08:26 PM   #2
walkerb
walkerb's Avatar
Re: power steering box
I know you can adjust but I think its not recommended. New rag joint?
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 03-22-2014, 10:36 PM   #3
Wrecked1982
Wrecked1982's Avatar
there should be a bolt with an allen wrench head blocked with a nut. its the ajustment. check to see if the frame is not cracked around the mounting bolts of the steering box
Wrecked1982 is offline   Reply With Quote
Old 03-22-2014, 11:25 PM   #4
hatzie
Moderator
hatzie's Avatar
Check the frame for cracks at the steering box bolts.
Check for slop in the rag joint.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 03-24-2014, 09:54 AM   #5
bryce6horse
rag joint was replaced with the sterring box. i didnt see any cracks. the play is in the steering box.
Rodney
1974 Chevy Big 10
1986 Chevy K20
2014 GMC Sierra
Old 03-24-2014, 11:05 AM   #6
Keith Seymore
Keith Seymore's Avatar
The proper adjustment procedure is documented in the Service "Unit Repair Manual".
There are two adjustments: base preload, and "overcenter". These are normally done with the gear removed and in the vise on a workbench. Both are determined by measuring torque at the input shaft with an inch pound torque wrench. The base preload is adjusted by turning the large nut that surrounds the input shaft; over center, which affects the on center feel of the vehicle, is adjusted with the set screw/lock nut visible on the top of the gear.
In leiu of all this you can try cranking down the set screw and see if that helps.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-24-2014, 11:14 AM   #7
hatzie
Moderator
hatzie's Avatar
You can adjust the steering box. However I don't recommend it. Any internal backlash is from worn parts. Replaced probably means a junkyard unit.
Look in my manuals post and page down to the Axles & Steering section. Download the unit repair training booklet for power steering. The second half is re-building and adjusting the Saginaw power steering box.
Old 03-24-2014, 03:10 PM   #8
bryce6horse
thank you gentleman for you help!
Rodney
1974 Chevy Big 10
1986 Chevy K20
2014 GMC Sierra
