2002 1500HD fuel pressure/hard starting
I have a 2002 1500HD with the 6.0. It's really hard to start sometimes. This morning I checked the fuel pressure and it was at 0 before turning the key, when I turned the key it jumped to 30 and quickly fell to 0, did it again and the same. When it does start, the pressure is at 45.
Bad fuel pump check valve?
Jay 2001 Pontiac Aztek GT |
Vintage 4x4s
Re: 2002 1500HD fuel pressure/hard starting
sounds like it. you could start with regulator since its up on engine and cheap n easy. take the box off the truck when replacing pump, way easier than dropping tank
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Thank you. I did check the reg. it seems to be fine though I know they can go bad without spewing gas out the line.
I think I will pull the tank as the truck has a massive headache rack, toolbox and iron rails! Heavier than a near empty tank! I may just go ahead and replace both for peace of mind.
![]() Join Date: Sep 2005
get a good AC DELO/ GM OR DEPHI PUMP THE aftermarket pumps dont last long or work near as good as oem
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2015 toyota Tacoma Daily 2012 Subura outback 2000 Tahoe 5.3l 420k 1999 honda accord General manager for Marco's Carwash & lube |
Replaced with a Delphi today and it' starting fine and running like a top.
| Bookmarks |
