Old 03-21-2014, 10:28 PM   #1
dbb1025
dbb1025's Avatar
Tools needed / recommended to install porterbuilt suspension
Hello All
I am going to be putting in a front / rear porterbuilt suspension. (Cannot wait
What tools do you all recommend I have available. I have a friend who will weld for me. I am talking about drills, saws, crutters, grinders. Thanks for the info in advance. I am going with the mild rear with the touring front.
dbb1025 is offline   Reply With Quote
Old 03-21-2014, 11:27 PM   #2
SCOTI
SCOTI's Avatar
Re: Tools needed / recommended to install porterbuilt suspension
High quality air hammer/chisel for popping rivets (cheap ones will take longer to bust them off).
Quality drill bits (multiples of the 1/2" size).
Angle grinder w/a cut off wheel & various 36 + 60 grit sanding discs.
Tape measure.
Level/s.
Another good thing to have around are misc pcs of angle steel to help align/square/clamp things (ex: R&P notches) in place. I used 1.5x1.5 3/16 steel.....
And most important.... If someone like me is helping, cold frothy beverages will be required for the most accurate results .
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-24-2014, 09:34 PM   #3
dbb1025
dbb1025's Avatar
Ttt
