Old 03-21-2014, 10:49 PM   #1
grs
Brake ?
C an I use a proportioning valve with drum on front , and rear?
grs is offline   Reply With Quote
Old 03-22-2014, 12:54 AM   #2
Captainfab
60-66 Nut
Re: Brake ?
No, you do not need a proportioning valve with 4 wheel drum brakes as long as you use a drum/drum master cylinder.
Old 03-23-2014, 12:09 PM   #3
grs
Re: Brake ?
Hey Cap. I bought a 2 and one half inch drop front disk set up for my 64. I wanted to install the front disk to rear drum power master cylinder on the truck. Later I will install the drop with disk on the front. Could I drive it with the proportion valve with drum to drum until I install the drop disk set up?
Also do you know if I need shock relocation brackets if I lower the rear 4 inches with lower springs? And do I need an adjustable track bar? Thanks for any info.
Old 03-24-2014, 01:35 AM   #4
Captainfab
60-66 Nut
Re: Brake ?
I don't know how safe that would be with a disc/drum master operating a drum/drum system. I have never done that. Why not just install the booster with the correct master for drum/drums? The master is only $15-20.00.
I don't know about the shocks or panhard bar, never lowered a truck with coils in the rear.
Old 03-24-2014, 06:21 AM   #5
PGSigns
PGSigns's Avatar
Re: Brake ?
I'll cover the rear question. No you do not need to move the shocks. you do need a set of shocks that are shorter. At 4" I did the track bar on mine. It is needed to get the rear back in the middle. If you have plans to go lower in the future get the long track bar that goes all the way over to the trailing arm. I did the drum drum power conversion on my 66 and used the parts recomended by Captianfab and it works great. I also have most everything to do the disc and will change the master cylinder and install the proportioning valve then.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-24-2014, 09:34 AM   #6
grs
Re: Brake ?
Jimmy
Do you know if Monroe makes the shorter shocks, and the part number? And where do I get the longer adjustable track bar, and what is the part number? For now I wanted to install the booster with master, and proportion valve. And later do the disk and drop on the front and rear.
Old 03-24-2014, 11:59 AM   #7
PGSigns
PGSigns's Avatar
Re: Brake ?
Look on CPP's web site for the track bar and the shocks. There is a lot of info in the suspension section on botht he track bar and the shock choices. Not sure on monroe numbers. I used KYB. What ever you do DO NOT RUN A DISC BRAKE SETUP with the drum brakes. This is safety issue and will greatly affect the way the brakes work. If you want power brakes now do it they way is should be and be safe.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-24-2014, 02:09 PM   #8
tincan1966
tincan1966's Avatar
Re: Brake ?
Just do like Captain Fab and PG said- buy a drum/drum master cylinder at the parts store for $20, install it on your booster for now, then when you upgrade to discs, then switch master cylinders to the one that came in your kit and install the prop valve then.
tincan1966 is offline   Reply With Quote
