Old 03-22-2014, 12:43 PM   #1
67stepper
67stepper's Avatar
For all the lowered (static dropped) Crossmember clearance?
Just ordered 2.5 drop spindles, planning on ordering front 1" drop coils next.
I'd like to go with 2" drop coils, but want to be able to drive it with out dragging the front end over everything.
So for all the static dropped trucks. How much clearance between the ground and the front crossmember or lower A arms?
Im also running 15's.
Pics of your front, and measurement, and drop, and tire combo would be helpfull
67 longbed fleetside switching to a 67 shortbed stepside with a 71 front clip, front disks, 2.5" lowering spindles w/1" lowering spring in the front, 5" lowering spings w/1" lowering block rear, 255/6015 front and 275/60/15 rear on 15x8.5 slotted mags, 355/350, 12 bolt 4.11 posi.
67stepper is offline   Reply With Quote
Old 03-22-2014, 11:45 PM   #2
67stepper
67stepper's Avatar
Re: For all the lowered (static dropped) Crossmember clearance?
no one has a tape measure or a picture?
Old 03-23-2014, 12:11 AM   #3
67ctener
67ctener's Avatar
You will be fine at 4.5" drop and 15s. Sorry have no pictures to reference but I know there are some running 5" drop with 15s. Check out lolife99 he has a slammed truck that's gotta be running 5-5.5" drop up front. Also put static drop in the search and youll get tons and pics and info on the subject
67ctener is offline   Reply With Quote
Old 03-23-2014, 12:17 AM   #4
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
It's likely that most of us are out enjoying the spring weather. Plus, there are a lot of variables in your first question.
Cut to the chase, I don't have a measuring tape by my computer right now. But I *do* have 2.5" drop spindles and 2" drop springs (all ECE).
Also, I installed new shocks and all new bushings....So, it's all pretty "fresh" down there.
You'll have an 'apples to oranges' comparison with mine, even so. Like with so many others' that have their own set-ups.
Those are 20's with 245/40's up front.
I can tell you with this set up, (and a 6" static drop in the rear w/shock relocators), I never even dream about a clearance issue up front.
Now, I'm not stupid enough to fly over those berms they put in parking lots to slow down the idiots.....But that aside.....
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 03-23-2014, 12:36 AM   #5
jmking9
jmking9's Avatar
Mine measures 6" to the crossmember, and +/-4.5" to the lower control arm. (from the ground)
I have a 2.5" spindle, 2" springs, with 235/70/15's currently on the front. I have no problems dragging as long as you use your head.
1970 SWB Build
jmking9 is offline   Reply With Quote
Old 03-23-2014, 12:40 AM   #6
67stepper
67stepper's Avatar
Thank you
I ended up buying 1" front lowering coils to go with my 2.5 lowering spindles.
that way if i want to go lower i can cut a little off. also ended up buying rear shock relocators and a adjustable trac bar.
Old 03-23-2014, 09:07 AM   #7
Mike C
Mike C's Avatar
Tire height has more to do with clearance than anything else. Especially on the outside of the control arms. Because the crossmember is centered between the tires for the most part, when they go up over an obstacle, it does too.
With that said, I have 2.5" spindles and 2" springs for my '69 Short Step... fingers crossed! I went with 235 55 17 which is a 27" tall tire which should help fill up the wheel well in addition to giving slightly more clearance at the crossmember.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-23-2014, 01:16 PM   #8
cjohnson6772
cjohnson6772's Avatar
67stepper: did you have any issues with lower a arm interference with 15s? Did you have to trim the ball joint area?
cjohnson6772 is offline   Reply With Quote
Old 03-23-2014, 01:57 PM   #9
67stepper
67stepper's Avatar
I didnt with my old set up of just a cut front coil spring, But im still waiting for CPP to ship my lowering spindles.
