03-22-2014, 02:42 PM | #1 |
PCM mount...
Trying to decide where to mount the PCM. With A/C and wiring harness it is tight under the dash.
Thinking under center console ....this will hold some heat being above the tranny tunnel. How much heat can the PCM take with little or no airflow? |
03-22-2014, 03:25 PM | #2 |
Re: PCM mount...
You'll be fine. Unless you think it's going to get a lot hotter in the console than it gets in the engine compartment, I wouldn't worry about it.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-22-2014, 05:52 PM | #3 |
Re: PCM mount...
mines mounted usign an 03 s10 mount to the driver side fendor
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-23-2014, 12:56 AM | #4 |
Re: PCM mount...
Under the seat on both my ls swapped vehicles. As well as a 1970 k10 I did for a coworker
03-24-2014, 12:36 PM | #6 |
Re: PCM mount...
Thanks MCB.....killer truck by the way
03-24-2014, 02:14 PM | #7 |
Still Learning
Re: PCM mount...
Thanks. If nothing else, I wanted to show the real estate I used to mount mine. And the wires on the stock harness are long enough to snake back behind and over the column. Ideally I would have mounted it under the driver's seat or somewhere totally not visible. But I didn't want to lengthen all those wires. good luck.
