03-22-2014, 07:53 PM | #1 |
Hard top fit
Getting ready to put the top on my 72 (single wall) and it seems when the bed holes are lined up, the top is over the windshield ,and when lined up with windshield, body bolts off by maybe an inch.Anyone seen this,could windshield frame be pushed back a bit ??
03-22-2014, 08:16 PM | #2 |
Re: Hard top fit
What kind of shape is your rocker boxes in? They are locate under drivers and passengers floor board. They support the body when the top is off. rusty or missing can cause sag.
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
03-23-2014, 08:07 AM | #3 |
Re: Hard top fit
I had forgot about that , the boxes seem good enough although I did remove the end caps because they were junk. would that be enough to do it ??
03-23-2014, 09:49 AM | #4 |
Re: Hard top fit
How do your rear door gaps look?
1969 Chevy Custom Camper 3/4 ton Rust free survivor 1972 Chevy Blazer CST 4x4 Almost Rust free survivor 1972 GMC Jimmy 2wd Undergoing surgery |
03-23-2014, 10:44 AM | #5 |
2WD Jimmy
Re: Hard top fit
Did you have a top on it before this one?
03-23-2014, 11:25 AM | #6 |
Re: Hard top fit
Try putting a floor jack under the front body mounts on a piece of wood running across the rocker boxes and putt some upward pressure on it. That should flex the windshield forward. The rear covers you tossed should be replaced as soon as possible as they are structual to keep the body stiff.
03-23-2014, 11:56 AM | #7 |
Re: Hard top fit
yes it had a top when I got it,it came off in pieces.the gap at the back of the door is a uniform 3/8 of an inch,plus or minus,but the gap at the front of the door is tight at the cowel and opens up at the bottom.I will try the jack trick latter this afternoon.You guys are great !!
Dave |
03-23-2014, 12:40 PM | #8 |
Carpe manana
Re: Hard top fit
Are you trying to use a 1x wall top on a K5 originally equipped with a 2x top maybe?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-23-2014, 01:21 PM | #9 |
Re: Hard top fit
came with a single,putting a single on.got a double I don't want thou
03-23-2014, 07:12 PM | #10 |
Re: Hard top fit
So I jacked it up on drivers side used a 4x4 to hit body mount and rocker box,top fell into place !!Ive been messing with this for a month debating what to do!what a dumb ass !!
03-24-2014, 04:26 PM | #11 |
Re: Hard top fit
The top may be on, but it is now under a bunch of stress once you let the jack down. You should shim/replace your body mounts so that the top is not fighting the body sag. Body sag will win that fight every time against the SMC/fiberglass top. The top on my Blazer goes on and off with no issues since I replaced and re-shimmed all of my mounts. Just my $0.02.
03-25-2014, 12:35 PM | #12 |
Re: Hard top fit
^^Agreed^^
Replace the body mounts, then shim apropriatly while watching the door gap alignment. When the door gap is even top to bottom, the top should also be in alignment, that is unless the doors were readjusted for the sag condition. |
03-30-2014, 05:20 PM | #13 |
Re: Hard top fit
CLESZKIE,SOCKALAMINSKI,
I have new mounts in there,I didn't do it so I don't know if they where just slammed in or what!Should I loosen all of them and torque them correct? And if shims are needed what doI use for shims?Thanks again guy's.Dave |
03-30-2014, 07:14 PM | #14 |
Re: Hard top fit
My blazer had 2 1/2" sqaure shims wirh a half inch hole in them. They varied in thickness from 1/16" to 1/8". There should be a sleeve inside the rubber bushings that pulls up tight against the washer and floor board so if thay are tight, I wouldn't worry too much about loosening and re-torque. The original bolts are tack welded to the floor, if you have to remove them, keep that in mind.
04-02-2014, 03:40 PM | #15 |
Re: Hard top fit
It's possible if they didn't do it correctly that the body will sag. When mine didn't have a top on for a couple years it lets the windshield frame sag as well.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
