![]() Join Date: Feb 2010
firewall pad poll, what did you use?
so I bought a firewall pad from classic parts of America. I'm not too keen on its fit. Where have you guys bought yours? How well did it fit?
Re: firewall pad poll, what did you use?
I used HushMat. Better sound dampening and heat insulation. Probably not as cheap and looks nothing like original, but wanted something that would work.
![]() Join Date: Mar 2005
I used FatMat. I welded up all of the holes in the firewall where the pad fasteners pop through, so the original style pad wasn't going to work anyway.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
thnx guys, any pics of the finished look?
Sorry no pics, since it's covered with carpet. But I did cover the whole bottom of the cowl, too, an area the factory pad doesn't cover. I also placed about 6 strips that were roughly 2" X 4" to the bottom side of the dash, which worked incredibly well to reduce noise or a 'tinny" sound. Still experimenting a little.
The part of these trucks that needs the most help with sound deadening and thermal insulating is impossible to get to- the roof, in between the inner and outer panel and also the "B" pillar behind the doors/upper cab corners. |
I have a hard plastic one that I got in a parts lot that I haven't put in yet. I'm going to put in some fat mat or something then put it in when the weater warms up. I think the guy I got it from said it was from LMC.
66 shorty ![]() |
mines a paper one. i might look into something different. is it molded then?
We used Roof repair material from Home Depot, aluminum/butyl rubber (like dynamat but cheaper) and closed cell foam insulation (thermo king brand from home depot) ran it from the top of the firewall all over the floor, up the back of the cab) cost about $ 2.50 per sq ft for both products, truck is cool and quiet.......Kieth
http://kieth.smugmug.com/Trucks/66-GMC/i-3HTCKCG since we covered the entire cab interior we did have to use a full rubber floor mat plus a reproduction stock rubber floor mat since the silver insulation and sound deadner would show if they were not covered) |
Damn, Keith, you took a lot of pictures. They sure come in handy for reference.
![]() Join Date: Jun 2006
I will either shoot the floor and back wall with bedliner or just use the heavy duty undercoating we use at work. My roof interior is all metal and I like the look so, I'm undercoating the roof from the outside and painting over it. The last coat will go on with high air pressure and it lays on fairly smooth so it will be barely noticeable.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
#11 | |
ps I am thinking about rearranging them and then making a directory of page numbers...........maybe when I retire..........hmmmmmmm I forgot to mention we did undercoat the bottom of the cab, fenderwells, etc......rhino liner would probably have been better but the 3m undercoating was cheap and easy to do. |
anyone else?
#13 |
![]() Join Date: Aug 2013
everytime i look at a parts truck i look for a original firewall pad to snag i seen one on the last pick but was there 4hrs and forgot it so if fits perfect an original. hushmats are great but too pricy for me and takes away the look im after. and i was hesitent about the new ones thks for the thread
#14 |
anyone have anything to add? I still haven't decided whether I want to use the onei have.
