70 c 30 to 1/2 ton uppers for rubber bushings.
Does anyone know if c 30 and 73-87 c 10 uca's are interchangeable? I can change the ball joints out. Only wondering for smoother ride and c 10 uppers are much more plentiful.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 70 c 30 to 1/2 ton uppers for rubber bushings.
yes
Thank You!!
Just the uppers? Yes but....
There might be a difference in the upper cross shaft mount stud diameters between the C30 & C10's (73-87 C30's are larger but I'm not sure about the pre-73's).
