Old 03-23-2014, 12:53 PM   #1
BarryB
BarryB's Avatar
What size brake line do I need???
I finally am to a point where I can rebuild and install my brakes, lines included.(lines are pretty much non-existent) I was going to buy a kit from Inline tube, But I decided to make my own. So I bought their flaring tool, Which is AWESOME I might as well say. http://www.ebay.com/itm/181212183753...84.m1423.l2649
Ok now to my original question. My truck is a Frankenstein project. Pieces from just about every year. LOL The brake lines have been botched. So what is the correct size for the rear and front brakelines. I'm going to be using SS. I believe. advantages or disadvantages???? I know I could figure it out, but Im being lazy and decided to give you guys a shout.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 03-23-2014, 07:30 PM   #2
PGSigns
PGSigns's Avatar
Re: What size brake line do I need???
I did mine with all 1/4". I like working with plane steel.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-23-2014, 07:54 PM   #3
BMERDOC
BMERDOC's Avatar
IIRC, drum/drum use 1/4" all the way around and disc/drum systems used 3/16" in the front and 1/4" for the rear.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-23-2014, 08:58 PM   #4
BarryB
BarryB's Avatar
Thanks guys, From the remnants of line there, I do believe it is 3/16 up front for disc, and the 1/4 going to the back. Another reason I decided to buy the flaring tool, was so I could make my own fuel and trans cooler lines, and give it a more professional job. I had bought pne the other type of flare tools, I would get more frustrated trying tomake a set of lines then it was worth. So in the bottom of the tool box that one will go.
Two rules in life.
