1986 c10 front bumper is offset???
I have 2 1986 c10's in my driveway and both f.bumpers sit over too far on the passenger side? Is there any easy fix ? Or even a hard fix? Thanks .
Re: 1986 c10 front bumper is offset???
I've a few of these and they all had the same problem...I never kept them long enough that they bothered me but this one is the cleanest one and I want to fix this...
Loosen rad cradle bolts and center the front end between the bumper if it's not far out.
![]() 1985 C10 2004 Avalanche |
#4 | |
The hood takes on the direction the cab is facing, shooting straight out. That means the fenders and rad support have to be scooted over in that direction to align the fender-to-hood gaps. Hard fix is to loosen the cab and turn it; easy fix is to cheat the front bumper as much as you can. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
Thanks...That makes a lot of sense!!!Quality control at it's best!
Make sure you do any adjustments with the hood open and ALWAYS close the hood with caution, checking all edges.
