Old 03-23-2014, 03:46 PM   #1
64chevtruck
Raise my transmission
Hi, I have been searching threads on this and havent found what I need,
I have a 292 with stock 4 sp manual trans, Ive Sectioned the crossmember 1.5, shaved the trailing arm crossmember, installed disk brakes and tube control arms.
The next thing that drags is the back of my transmission so I need to raise it, I was wondering if someone could suggest some other words to search for results or direct me to a thread that has info on this,
Im not seeing any aftermarket transmission crosmembers that I can bolt my 4 speed to either, Any suggestions>?
Ive searched
Transmission crosmember
so far,
Thanks in advance for any replys,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 03-23-2014, 03:59 PM   #2
NEWFISHER
NEWFISHER's Avatar
Re: Raise my transmission
Use a spacer between the cm and the trans and add a similar amount to the engine mounts or cut the rivets on the cm and lift the entire cm along with lifting the engine mounts or fab your own cm. With a protractor/ angle finder at the tailshaft make sure you are at 3 degrees downward and adjust/lift the mounts accordingly. Don't forget to watch the floor hump clearance, dizzy clearance etc. And make sure your rear diff is within 2 to 3 degrees of the tailshaft for no vibes.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 02-14-2025, 02:57 PM   #3
64chevtruck
10 years later I'm back, truck is back together, I'm down to just putting u joints in my steering rod.
Ty for all the info. I just made a new Trans mount. Pics soon
Old 02-14-2025, 10:43 PM   #4
Pick121
Pick121's Avatar
Way to stay with it, 10 years goes by before we know it on these projects!
-Pickman (Mike)
1964 C10 Fleetside LWB “George”
1963 C50 “Green Machine”
[SOLD] 2019 Silverado 2500HD
2020 Silverado 3500HD
My story (Welcome Page)
Pick121 is offline   Reply With Quote
Old 02-14-2025, 11:27 PM   #5
Getter-Done
Getter-Done's Avatar
Glad you are still with your Project.
As mentioned a Spacer to raise it up would be the easy.
The early bird gets the worm,
85 Chevy K-20
Old 02-19-2025, 08:20 PM   #6
SCOTI
SCOTI's Avatar
Depending on your set-up & a-arms, the steering shaft will likely clear w/a mild notch on an OE pre-73 upper drivers arm.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-27-2025, 06:01 PM   #7
64chevtruck
Ty for response guys. Scotti I notched my uca but I need more clearance
Old 02-27-2025, 07:30 PM   #8
SCOTI
SCOTI's Avatar
Wow.... My dually could plant the rails & 1.5" notched x-member firmly on the pavement w/no contact @ the steering shaft. I guess my OE upper arm could be notched a little more (?) or something else is different.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
