Old 03-23-2014, 04:33 PM   #1
BarryB
BarryB's Avatar
who is using clamshell style motor mounts??
I like the clam shell better than the factory stands. I remember reading somewhere they are fairly easy to use on these trucks. Is there a write up on how to install them, basically I need to know where I should place them for my small block to sit in there correctly without having the motor sit to far back or forward. Pictures always do me best.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 03-23-2014, 09:34 PM   #2
hugger6933
Re: who is using clamshell style motor mounts??
It is either in the FAQ section or the tech tips section. Go to the top of the page, click home the go to the upper left hand corner under the banner and click there it will take to to either one you click on. If you haven't been there you got to go anyway just for the info. Jim
hugger6933 is offline   Reply With Quote
Old 03-24-2014, 12:00 AM   #3
kwmech
The bolt pattern on the clamshell style frame stand will not bolt correctly in the small block position. When you install the frame stands it will set the small block 1-1/4 or 1-1/2 rearward in the big block position
