Old 03-23-2014, 10:11 PM   #1
54Caddy
GM Addicted
54Caddy's Avatar
How deep it too deep! Driveshaft yoke
Just got done putting in my flip kit on the 73. Now my driveshaft is in close I have maybe an inch gap. What is too deep in transmission. Should I be worried??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 03-23-2014, 10:13 PM   #2
54Caddy
GM Addicted
54Caddy's Avatar
Re: How deep it too deep! Driveshaft yoke
5/7 drop
..Mac’s Garage..
IG:MacsGarage
Old 03-23-2014, 10:36 PM   #3
mongoose
mongoose's Avatar
turn the brackets around.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 03-23-2014, 10:44 PM   #4
54Caddy
GM Addicted
54Caddy's Avatar
There already facing the back to pull axle back.
..Mac’s Garage..
IG:MacsGarage
Old 03-23-2014, 10:49 PM   #5
BMERDOC
BMERDOC's Avatar
If I were measuring for a new driveshaft I would bottom out the yoke, pull it out one inch and measure from centerline of the yoke to centerline of the diff yoke. If you feel like you have 1" of travel (at ride height) then you should be good.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-23-2014, 11:26 PM   #6
mixermike
mixermike's Avatar
I just had a driveline built for my 63. The driveline shop told me to do exactly what BMERDOC said. Push yoke all the way in , pull out 1 inch then measure ( at ride height )
mixermike is offline   Reply With Quote
Old 03-23-2014, 11:57 PM   #7
54Caddy
GM Addicted
54Caddy's Avatar
will check that out tomorrow at work, pull it up on the alignment rack.
..Mac’s Garage..
IG:MacsGarage
Old 03-24-2014, 07:25 PM   #8
bdiamond
That axle sure looks too far forward. Whats the wheelbase?
bdiamond is offline   Reply With Quote
Old 03-25-2014, 02:57 AM   #9
54Caddy
GM Addicted
54Caddy's Avatar
Attempted to make a drawing of how in installed flip kit. not sure if its clear though. so the flip kit bracket that goes in between axle and leafs has a hole in it for the leaf spring pin. I installed that bracket with the hole facing rear of vehicle, the bottom plate for u bolts is lined up with the offset hole and the center hole is facing front of vehicle. so is it installed correctly or do I need to flip it around? hard finding any information on this
..Mac’s Garage..
IG:MacsGarage
Old 03-25-2014, 03:06 AM   #10
mongoose
mongoose's Avatar
turn it around.
Old 03-25-2014, 03:18 AM   #11
54Caddy
GM Addicted
54Caddy's Avatar
dang will do now the problem is the c notch, its already installed to clear the way it is, ridiculous guess ill search for another frame now. no luck lately. couldn't find directions for flip kit from any manufactures websites. oh well
..Mac’s Garage..
IG:MacsGarage
Old 03-25-2014, 03:26 AM   #12
mongoose
mongoose's Avatar
My djm came with instructions.. tho the actual backets didnt fit.. just redo the notch? What kind of notch is it? Even if you have to cut it out its still less work and cheaper than a frame swap.
Old 03-25-2014, 10:03 AM   #13
54Caddy
GM Addicted
54Caddy's Avatar
Bolt in mcgauphys notch, only thing is if I move it back there won't be enought room for the front bottom bolt to be bolted to frame. Going to check with a local shop to see how much to move it back weld it in and box it in.
..Mac’s Garage..
IG:MacsGarage
