Multi carb
I'm really thinking about going with six deuces. Don't know why, but I've always wanted six deuces on an engine, but finding an intake that's reasonable ain't easy. But I finally found an offy for 3 and half. I wanted to know if anyone has ever had any big problems with offy intakes or with the six deuce setup, how hard are they on gas, I mean I don't really care( if I did I would restore my sunfire) but like 6 or 8 to the gallon, are they hard to set up, what carbs are recommended and all that good stuff
Re: Multi carb
Nobody has had experience with six x two setups.... I can't believe it
2WD Jimmy
![]() Join Date: Mar 2005
Re: Multi carb
I would search for a Hot Rodders forum. That is something old school guys might do on a deuce coupe.
Re: Multi carb
Would look cool. Your issue is going to be setting up and syncing the carbs. Not many people around that can can set up dual cars let alone three or more.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: Multi carb
You got a memory problem 1971!!
You asked the same question 10 days ago and got multiple answers. |
Re: Multi carb
i set up a 6deuce setup many years ago// was not worth the effort compared to the horsepower we could get out of a two 4 barrels unit
if you want to run a 6duece setup alot of guys just run on two carbs and the out ward 4 are just there for window dressing
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Multi carb
It would be cool until you close the hood...Six Deuces is an eye candy set up and anyone but a carb experts nightmare...I really like the three deuce set ups and they can be tuned for some awesome performance...But again, when you close the hood, only the eye in your mind knows...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
Re: Multi carb
With multiple carbs I would also make sure your fuel lines and gas tank are in excellent condition, if not I would replace every bit of it andthoroughly flush the lines out to remove any debris from the installation. The main reason people have problems with multiple carbs is trash in the fuel system, once set up multiple carbs should not need any more maintenance than a single carb.
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
