Old 03-24-2014, 12:54 AM   #1
NEWFISHER
NEWFISHER's Avatar
Which engine/injection set up?
Hey guys, Im currently running a warmed up 350, World heads, cam Edlebrock torker and a 1406 etc 700r4 and 4:10s and am on the fence on which direction to go next and would like some input from those who have swapped before me. I drive it 70 miles round trip for work and even though the mpgs are not the best, it would be nice to be in the teens, if it doesn't change oh well. Would like to keep the old school look but love the smooth reliable power from the 5.3s in our crew cab and wife's Tahoe.
Use the existing engine and run a new Tri Power old school set up? I have never driven one, worked on one but love the look.
Use the existing set up and install the Holley Projection system I have and am familiar with which will also accept a traditional air cleaner, have the easy start better mpg qualities but be an aftermarket system on a daily vs a GM system.
Use the existing set up and toss on a reliable as the day is long Tuned Port set up. Good performance, mpgs etc but looks like an 80s camaro under the hood.
Stop wasting everyones time and just do an Ls swap already. More costly and time consuming than the above. Would never have to swap again but looks like a new truck under the hood.
Input from those who have been down this road before is greatly appreciated.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 03-24-2014, 09:43 AM   #2
Re: Which engine/injection set up?
Swap the TPI. If looking like an '80s Camaro under the hood bothers you,what will looking at a way newer 5.3 make you feel? It just seems simple enough,you have a good motor now,and you can't beat factory reliability (and parts availability). the tri-carb set-up will give a cool nostalgic look and that's about it. You'll use less gas with a quadrajet.
Old 03-24-2014, 11:52 AM   #3
NEWFISHER
NEWFISHER's Avatar
Thanks for the input Special-K. Either Tuned Port or LS will obviously look new. The Tuned Port will cut down on costs as I can run it on this engine.
GOD BLESS AMERICA!
Old 03-24-2014, 01:14 PM   #4
Bigdav160
Bigdav160's Avatar
Air Fuel ratio is Air fuel ratio
I don't believe fuel delivery systems make a lot of difference (with the exception of direct injection) with relation to fuel economy. I properly tuned carb with get nearly the same mileage as a properly tuned EFI
In any case I like EFI for it's improved drivability (no pumping the gas pedel to set the choke).
I have a Tuned Port in my Camaro. I'm installing a 350 with a Stealth Ram into my Suburban. I'm going to try a MegaSquirt 2 as it's engine management system.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-24-2014, 11:09 PM   #5
Z10
Z10's Avatar
How about a F.I.R.S.T TPI set up. Think of it as a TPI on steroids. See my build thread for more info. Nice stuff.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
