Old 03-24-2014, 08:34 AM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Fs: 454 bbc
Pulled this out of my 71 SWB 4x4 this last weekend. I bought the truck with the motor in it, so I don't know the exact history but it ran strong back in 2004 before the truck was parked. No issues rather than it ran a little rich (carb). The reason I parked it was the drivers side exhaust manifold cracked from hitting the frame and the radiator popped a pin hole. I never got around to fixing it, plus two deployments in a 4 yr period and two other nice running trucks.
Here is the numbers:
Block: 361959 / '73-90 / 2 bolt block / 1978 motor
Heads: Stock - 346236 / no port work / torque heads (truck)
Intake: Older Holley Street Dominator
Ill include all brackets - with used ALT, WP, PS Pump Q-jet carb. Pulleys are included too. I believe all these were on the original stock set up.
Some one can come pick it up for $650.00
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
