Old 03-24-2014, 07:07 PM   #1
Frijolito1988
Mustang II Suspension questions
Hey guys so i am piecing together my Mustang II front clip. This is going to be a 56 GMC SWB.
So far What i know I have with the help of the forum.
Aftermarket MII Crossmember
Stock MII upper and lower control arms
Stock Mustang II spindles
9 1/4'' rotors that are 5x4.75 lug pattern ( camaro )
( I think these are aftermarket rotors that go on mustang II spindle but have a 5 lug camaro/gm car patern )
Now my question.
-Should i use the stock MII calipers and 9 1/4'' rotors ? Enough stopping power for a 56 GMC truck , small block, no racing just going to be used for cruising.
-Should i use the stock Coil springs and Shock / Strut ? Or are there aftermarket ones for the increased weight ?
Much appreciated.
Frijolito1988 is offline   Reply With Quote
Old 03-24-2014, 09:56 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Mustang II Suspension questions
Not a chance! Maybe marginal with power booster. On my 27 roadster I started with the Mustang brakes/rotors in a Ford pattern. Was unhappy even in an 1800 lb. car. Bought the kit for the 11 inch rotors/GM calipers for the Mustang spindle and it made a huge difference. IMO, don't even waste your time. I have a complete set, but in a ford pattern I'll sell you cheap!
Speedbumpauto is offline   Reply With Quote
Old 03-24-2014, 10:21 PM   #3
J48chevy
J48chevy's Avatar
Go with the 11" rotors. I bought mine from southern rod and parts and just starting to put it all on. Nice kit and the good news is if you select GM pattern rotors they also come pre drilled for ford bolt pattern also so you can choose either one. Here is the link. Not expensive either.
http://www.southernrods.com/chassis-...vy-pickup.html
My Build: 1948 Chevy Thriftmaster. Mustang 2 front end, LS1, 700R trans, Explorer Rear end.
http://http://67-72chevytrucks.com/vboard/showthread.php?t=606670
J48chevy is offline   Reply With Quote
Old 03-24-2014, 11:48 PM   #4
oldman3
oldman3's Avatar
X3, go with the larger rotors and calipers, will be alot happier...Jim
oldman3 is offline   Reply With Quote
Old 03-25-2014, 10:45 AM   #5
Frijolito1988
Thanks guys! Much appreciated.
Now should stock MII coilsprings and shocks suffice ?
Old 03-25-2014, 11:19 AM   #6
Speedbumpauto
Again, no....or maybe marginal with a small block with alum. intake and headers and no AC, PS etc. You've saved about as much as you can by using the spindles and control arms....and I'd even be suspect of the stock lower control arm using the short bushing and the strut rod set-up. By the way, you need to confirm your crossmember will take a stock lower unit. Many are made to take the aftermarket ones that use two bushings in the more traditional A arm configuration. You'll also have to weld in mounts for the strut rods somewhere in your fabrication plan. By the time you buy strut rod bushing kits, etc., you might be close to the cost of aftermarket control arms. Just something to think about.
Old 03-25-2014, 11:53 AM   #7
Frijolito1988
Actually i purchased a SWB frame that already had a camaro rear end and the MII crossmember A arms ect just needed the coils/shocks and brakes.
This is how i got it. Paid $600
Old 03-25-2014, 11:55 AM   #8
Frijolito1988
So i see speedwaymotors sells this complete kit to convert to GM 11' rotors / brakes. I am going to give them a call and order this ASAP.
http://www.speedwaymotors.com/Mustan...tern,2007.html
Old 03-25-2014, 11:59 AM   #9
slimneverdies
slimneverdies's Avatar
Do you guys know of any one who sells a 11" rotor that has the 5 on 5 or 5x127 bolt pattern for the mustang ll spindles???
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 03-25-2014, 12:23 PM   #10
Dan in Pasadena
Dan in Pasadena's Avatar
Frijolito,
Is this the frame that was on local SoCal Craigslist for quite awhile, I think the asking price was $695? If so, I REALLY considered going to look at it but didn't in the end because I simply don't have the space to store it/tear my truck down right now.
Did you carefully measure not only the "square-ness" of the wheel base but also the frame overall with side-to-side and diagonal measurements?
How about some pics of your truck as it is now?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 03-25-2014, 12:42 PM   #11
mr48chev
mr48chev's Avatar
They may exist but I haven't seen any that I know of. Most 5 on 5 GM rotors are a larger diameter than the 11 inch ones that are on most 5 on 4-3/4 brake setups.
The speedway kit you posted the link to is probably more than competitive with going out and buying the brake parts individually and it sure saves a lot of head scratching and pondering while making the brake swap a couple of hours process.
My ongoing truck projects:
Old 03-26-2014, 12:23 AM   #12
oldman3
oldman3's Avatar
Lots of guys seem to make them work, but not for me. If you go to page 23 post #567 of my build thread I have a write up on what I did (build thread in signature below)...Jim
Old 03-26-2014, 09:37 AM   #13
mr48chev
mr48chev's Avatar
Stock coil springs are usually up to the task on one of these trucks and as the weight bias is a lot different on the truck than on a stock MII the springs may be too stout for the truck. I'd probably want to go to at least an upgrade version of the stock shock.
Old 04-23-2014, 01:24 PM   #14
slimneverdies
You guys think there's enough space on the rotors to get the 5 on 5 bolt pattern drilled on them??
Long live SLIM
Old 04-23-2014, 01:45 PM   #15
solidaxel
solidaxel's Avatar
May want to check for bump steer on that rack and pinion, looks like the spacer is in the wrong position
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-23-2014, 03:45 PM   #16
_Ogre
_Ogre's Avatar
good catch solidaxle; there is no rack spacer, it looks like the po extended the tie rod with threaded rod.
that looks like a fatman x-member to me, my fatman is 3x4 tubing welded to the bottom of my frame
you can buy the rack spacer at any mustII fabricator, 4'' or 4.5'' if using the tbird rack
i added 4'' channel gussets on the frame for torsional strength but this is my fatman x-member
i strongly recommend the gussets (the engineerd in me)
shop air compressor timer
