Old 03-24-2014, 11:46 PM   #1
master 1969 c10
Active Member
how much room in the cab for us bigger people
hi am currently building 69 c10 fleet side from the ground up. I am a big guy 5'9" 400lbs i have a tilt wheel and plan on push the steering column as close to dash as i can and putting a smaller steering wheel on will i fit. I want to here from my bigger buddy on here or any other ideas u have or done that help. yes I no loose some weight but when your disable it's hard. I would like to here from my king size buddy's Thanks Doug
master 1969 c10 is offline   Reply With Quote
Old 03-25-2014, 12:43 AM   #2
wreckedchevy
wreckedchevy's Avatar
Re: how much room in the cab for us bigger people
dad's 6'4 probably around the same weight and he drove mine home no problem but the gigantic stock manual steering, steering wheel was pushing on his belly. I'm 6'1 and put over 200,000 miles on mine. leg room is more of an issue pushing in the clutch but I don't mind.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 03-25-2014, 08:07 AM   #3
hugger6933
I'm 6'3 375# and I have a tilt and have it down towards the dash in my 68 GMC with buckets. I have a smaller than stock for the time steering wheel, but one thing you need to remember when you push down the column it takes away a lot of the tilt range. It is the whole lever effect thing I guess. Jim
hugger6933 is offline   Reply With Quote
Old 03-25-2014, 10:03 AM   #4
Lattimer
Lattimer's Avatar
I'm 6'3" and about 420-ish. I put in a Flaming River tilt column and pushed it all the way to the dash, then made up the new steering shaft to match. I have a grant 13" steering wheel. I have 2-3" Between my belly and the wheel. I'd love to find a wheel the same diameter with a lot less dish, because that would open up several more inches for me and make the hand position on the wheel more comfortable. I just haven't found one I like yet.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 03-25-2014, 11:28 AM   #5
ho70
ho70's Avatar
Some have cut down the stock steering wheel or added a smaller wheel from a later model Chevy
Use search to find the stock wheel resize link
ho70 is offline   Reply With Quote
Old 03-25-2014, 11:56 AM   #6
cool68
move gas tank to under bed ?
cool68 is offline   Reply With Quote
Old 03-25-2014, 12:36 PM   #7
69GMCLonghorn
69GMCLonghorn's Avatar
Unfortunately this where I have found the "F" word was a bit ahead of GM in a similar year truck. My uncle has a '67 Ford that has TONS of leg room... but it's a goofy a** Ford with absolutely no following whatsoever. People turn a blind eye to him, he's been disowned by the family and is wanted by the police in 3 counties... J/K
69GMCLonghorn is offline   Reply With Quote
Old 03-25-2014, 07:26 PM   #8
Hubscrub
Cruzin
Hubscrub's Avatar
i'm large 6'3'' 380s i have smaller wheels on mine its ok i do wish for alittle more leg room but it not enough to make me not drive. when i got it i drove with the stock wheel for awhile. after marriage i got fater
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 03-25-2014, 07:47 PM   #9
OARNGESI
OARNGESI's Avatar
You can modify your seat and drop an inch
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-25-2014, 07:55 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
I'm 6' 2" and 300lbs. I have newer dodge seats in my truck with a smaller wheel. I fit alright but my legs tend to hit the bottom of the wheel. I found out real quick the leg room wasn't what I remembered from whemn I was 16. My truck was a manual and I'm switching over to an auto because I didn't like how I had to move my leg all the time to operate the clutch. I'm thinking of moving my column towards the dash a bit too when I switch to my auto tilt.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-25-2014, 09:31 PM   #11
ZombieWeinerDog
ZombieWeinerDog's Avatar
6'6" 350. Small steering wheel is a must. i have a tall body with shorter legs for my size, so leg room is good, but my head hits the roof sometimes.
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 03-25-2014, 11:12 PM   #12
master 1969 c10
Active Member
thanks for all the replies. I have the gas tank under the bed also I have a set of buddy buckets to go in I didn't think about putting the seat closer to the floor. this has been a full restore down to every nut bolt rivets everything is new or has been rebuild. so the people who told me i would never fit will eat my dust lol. I hope to be done end of this fall it's been a long 4 years.
Old 03-26-2014, 12:31 PM   #13
HeavyD
HeavyD's Avatar
You will fit it just won't be as comfortable as a newer one. I never thought these trucks had much room and see others feel the same way.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 03-26-2014, 01:05 PM   #14
DWilbur
I 6'-5" 365lbs I went the extreme building a crew cab to make room head and leg room is most of my problem. I added a spacer to the clutch pedal so it is closer to the floor and about an 1" up from the gas pedal helps.
DWilbur is offline   Reply With Quote
Old 03-26-2014, 02:07 PM   #15
72chevyk10
I built it
72chevyk10's Avatar
im confused. im 6'8, truck has no tilt and i have pleantly leg and head room. with the original seat foam crushed down i sink in nice and comfy. the thing i love about this truck is i dont have to straight arm the steering wheel to reach it like SO MANY other vehicles ive "tried" to drive. i can see how a belly might make these trucks hard to fit into though
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness
'98 dodge 3500 12v 5sp 4x4. the truck that actually runs
Originally Posted by prostreetC-10 View Post
I think the best and cheapest performance mod is to have someone that knows what the hell they are doing perform a tuneup on said vehicle.
72chevyk10 is offline   Reply With Quote
Old 03-26-2014, 02:22 PM   #16
Lattimer
Lattimer's Avatar
I have short stubby legs and a long torso. I'm 6'3" with a 30" inseam. Headroom is my biggest issue, especially since the Highliner I put in drops the ceiling about an inch. I do have a belly, so I could NOT comfortably drive the truck if it had the stock wheel and no tilt. My thighs would be rubbing the wheel and so would my stomach.
A lot has to do with how you sit in the truck also. I prefer to sit very erect and not slouch. However, If I slouch a little I have a lot more headroom. I had to get used to having my legs bent and my knees up higher vs sitting in a modern vehicle. It felt a lot more cramped when I first bought the truck than it does now.
I have a recovered stock seat with the original foam still in place and a few repairs under the cover. From what I have heard new foam will really make you sit high.
Shawn
Old 03-26-2014, 02:40 PM   #17
72chevyk10
I built it
72chevyk10's Avatar
yea ive got a 40" inseam. i dont fit in hardly any new rig especially to drive. my knees are always in the dash and i cant hardly reach the wheel with the seat all the way back. only thing ive found newish is 98-02 dodge trucks. the dash on them is far enough in i can fit my legs in without the seat all the way back. luckily that happens to be my favorite body style dodge. getting a 02 cummins rig here soon for a work truck
Old 03-26-2014, 02:41 PM   #18
67ChevyRedneck
67ChevyRedneck's Avatar
I'm 5'8", 175lbs and I DON'T FIT! My head is close to the ceiling, I wish I could move the seat about 2" back. The brake pedal is the worst, literally have to lift my leg back... keep thinking about cutting it and moving it back...
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-26-2014, 02:48 PM   #19
OARNGESI
OARNGESI's Avatar
I've heard the buddy buckets will give you less room than a bench
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 03-26-2014, 03:07 PM   #20
Lattimer
Lattimer's Avatar
In my Tundra I have the seat all the way back to fit the pedals comfortably. I do have the telescoping steering wheel, so reach to the wheel is no issue. I have perfect headroom in my truck. The ones with a sunroof drop the roof like over 2 inches, so thats a problem. No sunroof for me.
Shawn
Old 03-26-2014, 03:26 PM   #21
nicks diner
nicks diner's Avatar
I just pulled my gas tank out of the cab and I am in the process of relocating the tank to the back. This will not give me any more leg room in the cab?Will the seat not go back anymore? Everything is out of the cab right now getting painted this week .I was just curious if there's any more options. Hope I'm not out of line asking since its not my thread but since we are on the subject kinda curious.
nicks diner is offline   Reply With Quote
Old 03-26-2014, 03:50 PM   #22
67ChevyRedneck
Zero. None. The seatback hits the back wall of the cab under the window before it touches the tank area.
That's for the stock bench.
With the tank gone, you may find other seats will go back farther, because you can adjust the backrest to go up straighter, the stock bench has a fixed seatback unless it's a 67, and maybe some 68's folded forward. You may be able to adjust that to sit up straighter?
Jesse James
Project "On a Dime"
Old 03-26-2014, 04:11 PM   #23
nicks diner
Yeah its a 68. Got the tilt and the smaller wheel for my belly "260" 6" footer and spoiled with my 2011 jeep with lots of room. Maybe I will drive barefoot, lol..
Old 03-26-2014, 04:33 PM   #24
low&slow
I'm 6'3 and weigh a wopping buck 20 soaking wet lol. I have plenty of room, but leg room isn't really that bad. I got used to it. As for my dad who is 6'2 and almost 350-ish, with all stock interior in my 69 c10, his belly touches and leg room for him is a bit different as apposed to my leg room.
I'll let you know in the future how well I fit after I chop the top, add role bars, and all the other things I need in the darn thing
low&slow is offline   Reply With Quote
Old 03-26-2014, 04:42 PM   #25
cool68
maybe this?
