4 link question??
so i got my lower control arms back on and truck is sitting much better now fully aired out. took the truck out for first drive this past sunday and ran good first time. after pulling it back in the garage adding some tranny fluid i attempted to go back out. when i went to pull out i gave her some gas and the rear rotated back and put the u joints in a bind. im thinking maybe my u-bolts on the rear arent fully tightened down? i have no idea and am learning as i go, this is my first bagged and 4 linked truck ive worked on. Any ideas or things i could check would be much appreciated. thanks all.
Re: 4 link question??
What truck is it and what 4 link do you have on it ?
i have a 67 lwb and its a kpp 4 link
sorry ignore my stupidity this morning, its the KP components 4 link with cantilever set up and a watts link as well. Ive been trying to google adjustments but cant find anything
![]() Join Date: Jan 2011
Pictures of your setup will help.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
It shouldn't rotate that much. Pics to see if everything is in the right place. Are your driveline angles correct?
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Yeah u r right pics always help. I will get over to the garage and get some good pics of the rear set up and u guys can look and point out anything if it doesn't look right. As far as the driveline angle I'll have to get under it and get the angles. I can't say for sure what it is at while at drive height.
This is the only pic I have that u can half way see the rear setup
Here is another
