assembly manual help
Looking for the best assembly and wire manuals u guys use. I see there's bunch to choose from just want to buy the one with the most info thanks
Have you looked at the F.A.Q section on here for the wiring diagrams? they are very nicely done, and in color! makes it very easy to Identify those pesky wiring problems! I bought the factory assembly manual, it helps tremendously, especially if your working with a "Basket Case" like I am........I've restored a '69 Camaro and it too, was a basket case. I bought a "Parts Car" just for the interior and small stuff that was missing, as well as some of the larger parts, I.E. Brackets, wiring harness,etc.....good luck with your Build!
Ben Smith http://67-72chevytrucks.com/vboard/s...d.php?t=185856 HTH |
Re: assembly manual help
Thanks for help the diagram is going to help a lot I knew I was in trouble when I saw speaker wire for the tail light wiring lol
yeah, that part of the harness is almost impossible to find. I found out that the '73 to '84 chevy trucks used an almost identical tail light harness, only the lamps themselves are different, but basically the same harness, the plug that goes into the intermediate harness, is exactly the same plug! so find one of these tail lamp harnesses and add your sockets/pigtails and your lamps.
and Voila! Have a good one! Ben Smith ![]() |
#5 | |
The Older Generation
You will find them here: http://67-72chevytrucks.com/vboard/s...d.php?t=558016 LockDoc
