03-25-2014, 08:23 AM | #1 |
Installing Rack & Pinion on your C10
Hi guy's, I'm a new guy on here I have a 66 short panel truck, I've bagged it, got 3 in drop spendals and raised the k-member 1-1/2 in the frame (after reading some builds on here there where better ways of doing that!). But anyway I want to put a rack & pinion on it but I don't know the best way to do the tie rod ends? I was curious what you all thought! O and by the way this forum rocks!
03-25-2014, 08:33 AM | #2 |
Re: Installing Rack & Pinion on your C10
I don't know the answer to your question. But I wanted to say Welcome.
03-25-2014, 08:42 AM | #3 |
Here's a few pic's of her!
03-25-2014, 08:45 AM | #4 |
03-25-2014, 09:27 AM | #5 |
Rob at no limit engineering makes a rack and pinion kit,
Here is a link: http://nolimitengineering.com/produc...47&id=26244520 |
03-25-2014, 09:29 AM | #6 |
why do you want the rack and pinion over the standard drag link and gear box set up? is it a clearance issue?
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
03-25-2014, 09:56 AM | #7 |
03-25-2014, 09:58 AM | #8 |
I'll check it out Kieth, thanks!
03-25-2014, 10:13 AM | #9 |
Got any build pictures of how you did the frontend? That thing looks sweet, love the stacks!
03-25-2014, 11:17 AM | #10 |
03-25-2014, 11:45 AM | #11 |
Brasshead, here are the pic's I got!
03-25-2014, 12:03 PM | #12 |
I built my own front cross member, with a rack and pinion mount. What I had done was had the stock spindels reamed out to the newer taper. (OEM is 1.5 taper and the T-Bird rod ends I used are a 2.0) They fit well now.
I also did not narrow my front end any, which, looking back would have been a good idea, as I did have a little trouble getting my toe in close and having a safe amount of threads in the tie rod end. Ended up with some inner tie rod spacers in the rack, which I am not big on. I have since found that there are tie rod ends available that are 1.5" longer in the threaded section, which would have solved my whole problem, too. It's all a learning curve when you start building your own parts. There's a lot of good kits out there, and my decision was purely with budget, and I wanted to see if I could do it. |
03-25-2014, 12:56 PM | #13 |
Look's like you cut your frame to fit over the cross member. That's not a bad idea. I should have seen your truck around, do you go to many shows? If you get a chance you should come to Kunkels Drive-in over in Connersville this summer they have a cruise-in twice a month.
03-25-2014, 01:46 PM | #14 | |
03-25-2014, 01:52 PM | #15 | |
03-25-2014, 03:14 PM | #16 |
You may want to check this show out it's in Lewisville right on US40. Lots of cool cars and cool people, your ride would fit right in.
03-25-2014, 04:27 PM | #17 |
If I got it back together, I will for sure! Its in pieces at the moment! Doing a T-56 swap and all that goes with it like, drive shaft, clutch linkage and rear end gears.
03-25-2014, 04:46 PM | #18 |
"Where were you in '62?"
1960-87 Chevrolet & GMC Pickup Bolt-in IFS Package
http://67-72chevytrucks.com/vboard/s....php?p=6503312 I have a Mustang II IFS Clip on my 62. http://67-72chevytrucks.com/vboard/s...d.php?t=321173
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
03-25-2014, 04:55 PM | #19 |
Bro thats a SHHHHWEEEEEETTTTT Panel!
1964 Chevorlet Custom 10 350/350 ,ps,mb,A/c,BBW -Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=608625 1969 Chevy Nova 2 dr I6 250/powerglide 1967,68,69,70,71,72 Chevy Frankenstein |
03-25-2014, 05:07 PM | #20 | |
03-25-2014, 05:09 PM | #21 |
03-25-2014, 05:14 PM | #22 |
Ok ? if I'm mostly replying on this forum from my phone how do I get my pics to show up? (I'm not real tech savvy!)
03-25-2014, 05:38 PM | #23 |
what type of smart phone do you have?
03-25-2014, 05:45 PM | #24 |
03-25-2014, 06:01 PM | #25 |
Ok, I'm on the wife's Kindle! Want to show you guy's what I'm working on now, other than the rack & pinion
