Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 03-25-2014, 11:10 AM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
Neutral safety / starter relays
I have the black 87 style relay that is powered 12v hot by the key i break the ground through the micro switch on the shifter in neutral and park . It seems these relays are having a hard time with the amp drw of the starter solinoid . Should this relay be a heavier duty relay ? Say like a S-55 borg warner ? When i bypass the relay the starter kicks in fine . Seems like the relay cant handle the amperage after a while . What are you guys using for this ?
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 03-27-2014, 04:09 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Neutral safety / starter relays
The solinoid can be 40-50 amps at the point the key hits . The Ford relay can handle this inrush . The small black relays cant over time . You use the Ford relay to fire the chevy solinoid . Mopar also has something like this
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
