cab mount kit
I have seen some catalogs sell a cab mount kit for 60-66 and some split them up into 60-62 and 63-66. Is there a difference. in some of the catalogs that split them up they say that the 60-62 kit does not come with new bolts.
Re: cab mount kit
I normally see square cab mounts on the earlier cabs 60-62 and round on the 63-66. Also noted recently when we went to get the newest 63 (cab was off the frame)....I had a nice set of 61 mounts that we took with us so that we could mount the cab for transport. The 61 mounts were shorter than the stock 63 round ones were.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#3 | |
Re: cab mount kit
Re: cab mount kit
Just high enough to get them in. Remember thats higher than what its required to be when getting the old ones off.
Live and let live ![]() |
Re: cab mount kit
The cab was completely off the frame when we arrived. But, you will need about 2" of clearance to get the upper mount in w/the metal sleeve. The the lower mount will go on, the washer and then the bolt. The rears bolt up through the cab....the front two have bolts that drop down from inside the cab and have nuts that will attach.
Re: cab mount kit
Mine are bad , but I can't replace them now. Can I spray them with something to stop them from getting worse? Like silicone spray.
Re: cab mount kit
It may help temporarily, but if the rubbers are shot...they will eventually need replaced.
