Old 03-25-2014, 03:03 PM   #1
swnicholson
upgrade for stock brake booster on 1970 C20 Camper
Hi, I have a 1970 C20 Custom Camper and am a wrenching novice. It's something I watched my grandfather do, but never did it myself. Now I've inherited his pickup and I've jumped in and am loving it. Can see how this is very addictive This is my first post, hoping to get some feedback.
I'm looking to upgrade the brake booster. On the SPID is "J70 Brake Booster Equip", although I'm not 100% sure the one that's in there now is factory. Photos attached. I think the wetness in one of those photos is from the recent bleeding I did, but I should double-check there isn't some other leak.
Where should I look to find an upgrade to the booster? I did a lot of research and nothing turned up. Will I have to replace the lines?
Thanks!
-Scott
swnicholson is offline   Reply With Quote
Old 03-25-2014, 04:05 PM   #2
cleszkie
cleszkie's Avatar
Re: upgrade for stock brake booster on 1970 C20 Camper
It appears that you already have the appropriate dual diaphragm booster and master cylinder for a 3/4 or 1 ton truck. If the booster and master cylinder are in good working order and your engine is generating sufficient vacuum, this setup should do the trick for you. I have a 1/2 ton Blazer which I upgraded with the same booster and master cylinder combination when I upgraded to 1 ton axles, and my braking improved tenfold. Swapping from 1/2 ton to 1 ton booster and master cylinder required new hard lines. But you will not need to do that. If you want even better braking, you can go to a hydro-boost setup used on many late model trucks and vans.
cleszkie is offline   Reply With Quote
Old 03-25-2014, 06:48 PM   #3
yuccales
yuccales's Avatar
First, welcome to the forum! Second, where's the pics of your truck! We need 'em.
yuccales is offline   Reply With Quote
